Member # 8402
Background on the motor - It is a 1989 5.8L truck motor (speed density), converted to MAF with an aftermarket harness, using an aftermarket MAF, and an A9L computer. It has ran flawless since the first time i started it.
Tonight I reassembled my buggy to the point that I could start it up and test some things out. Here are the events 1- battery was dead, found my booster. After 3 attempts the buggy finally starts. 2- Idle is crappy, pretty much stalls as soon as it returns to 700 rpm or so. Might be because I had the battery cable disconnected to it lost all adapt table. 3- I clean the MAF and leave the air filter off (air filter was solid mud). This might not have anything to do with the saga, but who knows. 4- Buggy starts fine and idles OK. Within 5 minutes the buggy idles great. 5- I let the coolant temp reach operating temp, then flip on the electric radiator fan, and the engine stumbles for about 1 seconds then stalls. I have 2 radiator fans, the same problem happens regardless of which fan I turn on. 6- repeat 5 numerous times. 7- restart the buggy but use the throttle to keep it running when i turn the electric fan on. Even at 1000-1200 rpm it has a miss. 8- restart buggy with electric fan off and everything is perfect at all RPMs Pull codes, here is what I have KOEO 81 Boost control solenoid - Solenoids AIRD solenoid - Solenoids and Air Injection 3.0L SHO - Inlet Air Solenoid - Solenoids I don't know what this code is, but everything I read shows it is because smog is removed 82 2.3L TC - Fan Control wire shorted to ground - A/C and Fan Circuits AIRB solenoid - Solenoids and Air Injection same as above, it is because smog is removed 84 EGR Vacuum Regulator - Solenoids EGR cutoff solenoid - Solenoids EGR Vent solenoid - Solenoids EGR and smog removed, makes sense.... 95 (R) AIR not Diverting (AIRD) - Air Injection another smog code Memory Codes 33 ALL - (O, M) EGR did not open/ respond during test or if memory code, did not open intermittently another smog code, EGR deleted 66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - This one bothers me. If the MAF is operating correctly until I turn my fans on, then I am suspecting some sort of electrical interference. My fans draw big amps and are about 10 inches away from the top of the motor (and MAF). What confuses me is that I have never had this issue. Or, there is option C- none of the codes above are causing this issue. What sensors on the motor would be extremely sensetive to electrical interference? Why would it just randomly start now? cold weather? Can someone tell me if code 66 will set a CEL? I did have the CEL come on, and the RPM smooths out. About 5 seconds later the CEL turns off and the RPM stumbles. It does this over and over
Inviscid Motorsports #9009 Thanks to; Ironman Offroad - Motorcity Machines - Branik Motorsports |
Member # 8402
someone from my local board nailed the problem. I had left the air filter off. when I turned a radiator fan on, it was disrupting the airflow in the engine bay, which caused bad flow readings through my MAF, eventhough I thought my MAF was way out of the way of the airflow. I put the filter back on and it idles great.
#4 (permalink) | |
Member # 109328
I am running EEC IV on my wife's truck and am fighting an idle issue. It has an engine driven fan so turning it off isn't an option. I will pull it off and see if it fixes the problem ![]() If so, then I suppose I will be building an air box. Derek |
master lurker
Member # 104639
read two posts up, very common issue..
--------------------------------------------------- GOT 99-04 UNIT BEARING HI-STEER?? check out the super ranger 86' RANGER-39.5'S-4.0L-M50D-9"-DETROIT-5.14'S 90' RANGER-42'S-BLOWN 302-E4OD-60/10.5-5.38'S-12 BOLT H1'S
#6 (permalink) | |
Member # 83920
![]() As for HO Shorts problem.... Please explain to all of us here, how he has a charging problem, when he says nothing about it in his thread, and specifically states that he has a mechanical fan... Guess reading comprehension isn't your strong suit.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. Last edited by dahoyle; 01-21-2012 at 12:49 PM. |
