TTB Limited Slip ???'s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-21-2012, 04:30 PM   #1 (permalink)
Member # 194934
I have an open carrier on the front end of my 87 Bronco. I was wanting to put a factory LS carrier in it. I found one for about $75.00 that needs clutches , but, the rest of it looks pretty good as far as the inner pinions and side gears go. I keep seeing these write ups about how you have to add a spring in between the slip and stub to keep the axle from backing out of the pumpkin on the passenger side b/c the "e" clip wont fit onto the end of the axle shaft that retains it when a LS carrier is installed.
What I am trying to figure out is how Ford kept the axles in the factory LS units from the start or am I missing something here in translation?
Where is the cheapest place to get kevlar clutches or carbon fiber clutches on the web?
Bruno2 is offline   Reply With Quote
Old 01-21-2012, 05:13 PM   #2 (permalink)
Member # 25322
I think they are using factory rear dana 44 L/S units. I know that with Ranger's and Expo's, we used Jeep rear Dana 35 L/S and locker's........
----In 5/16" chain we trust----
I can operate any vehicle beyond it's limits
GONRACIN is offline   Reply With Quote
Old 01-21-2012, 06:11 PM   #3 (permalink)
Member # 189778
I'm looking for the same information. I don't want to tear the whole front end apart to find out i had gone the wrong direction. My powerlock is out of my Willys with 30 spline axles and 4.88 gears.
Backroader is offline   Reply With Quote
Old 01-21-2012, 06:14 PM   #4 (permalink)
Member # 194934
I am sure somebody that frequents the board in this section will have the info. If not then I may look for another section to post it in. However, I would think the Ford gurus here would know all about some TTB shit.
Old 01-22-2012, 06:47 PM   #5 (permalink)
Member # 10063
E-clip eliminator:
http://www.therangerstation.com/tech..._external.html
Spring shown fits the D44 TTB just the same. Don't weld on your shaft though, a couple hose clamps around the ends of the boot is plenty to hold the spring in place.
Also, some L/S carriers will have a provision to get the clip in there... though I'd probably still do the clip eliminator just the same if you plan on wheeling it offroad at all (makes replacement of a broken axle shaft 10× easier).
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 01-22-2012, 07:46 PM   #6 (permalink)
Member # 204828
I have installed the spring on mine. Driven on the highway, crawling over rocks, or blowing through mud and snow. No problems. Ive also done a removable diff cover on my d44 hd ttb with no problems as well. Hope to do a thread on it at some point.
Check out my videos of 4 wheelin, car audio, and random by looking for tom58c on youtube.
tom58c is offline   Reply With Quote
Old 01-23-2012, 07:01 PM   #7 (permalink)
Member # 40162
I dont know for how many years they ran, but in the early 80's, the TTB setups had a bolt on retaining plate type setup- same concept as what holds in an axleshaft on a Ford 9 inch rearend.
"Time you shut your cake-hole, YOKO!!!"
wyldstallyn73 is offline   Reply With Quote
Old 01-23-2012, 07:51 PM   #8 (permalink)
bremen242's Avatar
Member # 28687
Yeah, I am pretty sure it was from 80-81.. Hard to find.
Originally Posted by HAPPYJOHN View Post
Reading comprehension & Hennessy don't mix!
bremen242 is online now   Reply With Quote
Old 01-24-2012, 05:57 AM   #9 (permalink)
Member # 152532
x2
f350n4.6ranger is offline   Reply With Quote
Old 01-24-2012, 06:08 AM   #10 (permalink)
KyleQ's Avatar
Member # 83837
When I put the D50 in my truck I installed a power lok and LOVE it, with 4.56 gears I went through about 8 ujoint/axle sets when I was wheeling it, full ciricle snap rings with spicer joints made a huge difference in longevity.
As for the missing retainer, I've got a spring sitting inside the middle slip joint forcing the axle shafts apart, keeping pressure on the wheel seal on the wheel side and keeping the shaft inside the diff on the diff side. I've had issues with the cap popping out and intermediately loosing 4wd when going over bumps (shaft coming out of the locker) - I'm willing to give that spring mentioned above a shot, minus the ghetto bugger welds though, lol.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers
Bronco Build Thread
KyleQ is offline   Reply With Quote
