Member # 141634
Early bronco 9" bend axle?
Hello, I have a problem with my ford 9" was leaking bad and after review I have my doub about the axleshaft being bend, the drum was rubbing against the backing plate......how can I make sure the axlexhaft is straight?
tnx for your advice.
Member # 168108
Get a new axle and truss it. Common sense.
If you drove with a bent housing you may have screwed up the splines on your axle shaft and spider gear. Junkyard a new axle. Ive bent several 1/2ton housings and pulled axle tubes on 8.8s.
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch '90 f-250 project, boat sides, 3/4 link, cage etc '91 Volvo 940se holset turbo, olive drab, lifted rally car Last edited by dieselboy740; 02-17-2012 at 08:59 AM. |
Member # 42245
Roll the axle on your garage floor and watch the flange??? Flanges bend pretty easyand more than likely the problem.
77' Bronco,5.0 roller,Klune 4:1,37s,Wristed radius arm / 85' Runner-5.29s,Detroits / 79 F350 4x4 |
Member # 56456
If you have a dial indicator you could simply spin the axle in the housing and watch runout. If the housing is bent that can be fixed.
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205 |
Member # 83920
Bearings?
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. |
Member # 210335
If all else fails, buy a bearing, remove the axle, and push it into the housing and try moving it around. Sometimes the housing itself is just worn/hallowed out. If it is you can stop the leak for a while, but, not fix the problem.
Jack the leaking side way up, throughly clean where the bearing mounts, use red RTV along the bearing mounting surface, install the axle, let it sit overnight. I took a MIG welder and touched mine up on a very low setting. |
Member # 104085
No 28 spline and 38" tires but I had rebuilt the diff, hhad new bearings pressed on with new brakes and drums. Nine inch is a quick change axel on the track but still a light weight 1/2 ton axle. My 2 cents
#11 (permalink) | |
Member # 64139
The 9" is plenty strong with the right modifications and some commonsense. Obviously it sounds like you need a truss and possibly a new housing. What year is your bronco? if it is earlier then this is a good time to swap in a big bearing 76'-77'. then do yourself a favor and search a little on 9 inch upgrades. after you learn some stuff decide for yourself what upgrades you need and don't
73' Bronco with stickers and stuff |
