NP205 Output issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-19-2012, 01:50 AM   #1 (permalink)
broncoguy's Avatar
Member # 110063
NP205 Output issue
Got an NP205 issue? Maybe? It's a ford 205 so I figured I'd ask the Ford guys.
I Googled and searched on here and didn't find my answer.
I just got my new 1350 CV driveshaft and flange for the rear of my Bronco. After installing the Flange on the output i noticed i have about an 1/8 inch or so of end play in the rear output shaft. Is this normal? Or do i have a problem?
I don't remember having that much play with the old 1310 cv yoke, but then again i wasn't really looking for it either.
broncoguy is offline   Reply With Quote
Old 02-19-2012, 09:13 AM   #2 (permalink)
andy71118's Avatar
Member # 124337
problem...
My lug nuts require more torque than your Honda makes.
andy71118 is offline   Reply With Quote
Old 02-19-2012, 09:17 AM   #3 (permalink)
KyleQ's Avatar
Member # 83837
All 205's are the same, gears are interchangeable, general tech would have been fine. Something sounds off - they are easy as sin to work on, my dad and I took one apart for the first time with the aid of 3 or 4 cocktails and we figured how to put it back together just fine
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers
Bronco Build Thread
KyleQ is offline   Reply With Quote
Old 02-19-2012, 08:45 PM   #4 (permalink)
crs msl's Avatar
Member # 181997
Yup, shouldn't be any play.
79 Bronco -- 400-C6-205 -- OX'd HP60 x Welded FF14Bolt -- 39.5 Iroks
crs msl is offline   Reply With Quote
Old 02-19-2012, 09:18 PM   #5 (permalink)
broncoguy's Avatar
Member # 110063
End Play
Didn't think it was right. Guess i'll pull it apart and see what I screwed up.
Thanks for the help
Old 02-20-2012, 02:22 PM   #6 (permalink)
Member # 38200
Never had mine apart, but here's a diagram that may be helpful.
Does the new yoke bottom out against the bearing? If the splined length is too short it may leave a gap that will cause play. Check if it's the same length as the old one.
The snap ring holds the bearing between the retainer and housing. The yoke pulls the shaft against the bearing.
If you remove the output assembly, there are needle bearings between the input and output shafts that will fall out and need to be rounded up.
Quick & Dirty is online now   Reply With Quote
Old 02-20-2012, 07:13 PM   #7 (permalink)
broncoguy's Avatar
Member # 110063
Well, judging by your diagram and what I can remember, I am almost positive I got it back together correctly. I'll compare the length of the new flange against the old yoke when I get home. Thinking maybe the new flange is just a tad bit long.
Sent from my SCH-I500 using Tapatalk
66 Bronco, 289, NP435, 1356/205 doubler, long arms, f-100 rears, stretched to 101", 42's, 60 front, shaved 14 bolt rear, full hydro...yada yada, bla bla bla.
Old 02-20-2012, 08:44 PM   #8 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
i would think that the new yoke is actually to short and not contacting the roller bearing allowing the shaft to end play in/out.
trkklr77 is online now   Reply With Quote
Old 02-20-2012, 09:39 PM   #9 (permalink)
broncoguy's Avatar
Member # 110063
Ya, your right. I was thinking backwards as usual.
Old 02-21-2012, 11:20 PM   #10 (permalink)
broncoguy's Avatar
Member # 110063
Well, the flange and yoke measure out the same. Put the old yoke back on just to double check, play is still there. My best guess now is I must have forgotten a spacer between the input and the output shaft. Great, get to tear the whole thing apart again and haven't even driven it yet! Oh well, it's my own damn fault
