Link Setup on my Ranger - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2012, 08:20 AM   #1 (permalink)
Member # 159220
Hi guys, So ive got a '97 ranger that used to have a rough country 6" setup on it, and recently I decided to go to tons. Dana 60 front/rear. The rear is all set with leafs, but for the front end I am still a little undecided. I recently have done quite a bit of research on 3 link wishbone setups, but in the past have always thought about going with a triangulated 4 link. The truck will be setup for the rocks, rolling on ~37" tires. Can someone give me some insight on what would be better for my application? I know its kind of a broad question, but I am pretty new to all of this. The front axle is out of a 2005 f250 if that helps any. Thanks a ton!
cgriffin224 is offline   Reply With Quote
Old 02-23-2012, 08:27 AM   #2 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
well if you havent already cut off the factory radius arm brackets then you need to start with a radius arm setup.
trust me, if you havent researched suspension design and handling characteristics then its not going to perform worth a fuck.
and if you think a RA setup is inferior to a 3 or 4 link then you might want to check out cousin willard (offroad designs truck)
youll be much happier with the effort put into the front suspension if you go with a RA setup than you would if you "tried" a 3 or 4 link...
jeep is getting a new home!
NEW PROJECT ON THE HORIZON!!!
E-350
12 valve cummins, 2006 F350 axles, 6" lift and 37's
FordX4-offroad is offline   Reply With Quote
Old 02-23-2012, 09:14 AM   #3 (permalink)
Kyle M's Avatar
Member # 165077
A 4 trangulated link would require a hyro steering or something like that...keep that in mind.
Just do some research, I can't tell you what would work best for you.
93 RANGER 4D'S/V8/TONS
Kyle M is online now   Reply With Quote
Old 02-23-2012, 09:27 AM   #4 (permalink)
150
crawler
150's Avatar
Member # 167647
the radius arms or 3 link is gonna be your best bet. but if you dont know much about link setups then you could setup some leaves that could perform well.
1989 f-150 dana 60 front, 10.25 rear. 3 link with coil overs out front. chevy 63s double shackled out back. bobbed bed. rollin on 37s
the build up of ^ truck /forum/ford/1015047-project-89-f-150-a.html
150 is offline   Reply With Quote
Old 02-23-2012, 10:42 AM   #5 (permalink)
party wagon
Member # 202878
Originally Posted by 150 View Post
the radius arms or 3 link is gonna be your best bet. but if you dont know much about link setups then you should continue educating yourself, because you cant put leafs on a 05 and newer superduty axle .
FIFY
E-350
Old 02-23-2012, 07:20 PM   #6 (permalink)
Member # 159220
Alright, Thank you! I have been looking into doing a radius arm setup slightly. Or even possibly a 4 link setup that was made for the f250, but just the arms. But just the arms. I am going to keep an open mind, and go with whatever ends up being easiest, but best in the long run. I just dont want to have to go back through it all and re-doing it later on.
