#127 (permalink) |
Member # 46318
I'm guessing you mean the 2 leaf springs I removed? They are diesel springs. Bronco graveyard has them new for $295. I'd take $150 for the ones I have. The bushings are good, and the springs are in good shape.
Project Ol' Skool '37 Chevy: /forum/ford/1049898-project-old-skool.html 1979 F-350 build: /forum/ford/855113-79-f-150-build.html |
#130 (permalink) | |
Member # 46318
I am waiting on my 3/4'' reamer to show up in the mail so that I can ream the bushing sleeve on my springs to accept a 3/4'' bolt. I am also heading out to pickup a parts truck, which will supply the rear axle today. I did a clutch job and transmission for the parts truck. We'll count that as a freebie
Project Ol' Skool '37 Chevy: http://www.pirate4x4.com/forum/showthread.php?t=1049898 1979 F-350 build: http://www.pirate4x4.com/forum/showthread.php?t=855113 |
#131 (permalink) |
Member # 187456
Updates?
[QUOTE=bigford;10609690]On a side note: I remember telling my second ex wife " My truck comes first, then my job, then you " I never liked that woman. [/QUOTE] |
#132 (permalink) |
Member # 46318
I have been fighting with the super duty spring bushing sleeves. I got them drilled out to 3/4'' tonight, I have the springs hanging with the offset shackles, I have the parts truck in the yard, and best of all, I have a brand new baby daughter that was born on the 10th. I will try to get some pics gathered tomorrow.
Edit: Oh yeah, I forgot, I think I am going to use a different cab ........Don't worry, it is still Ol' Skool
Project Ol' Skool '37 Chevy: http://www.pirate4x4.com/forum/showthread.php?t=1049898 1979 F-350 build: http://www.pirate4x4.com/forum/showthread.php?t=855113 Last edited by AllGoNoShow; 04-13-2012 at 11:01 PM. |
#134 (permalink) |
Member # 177573
Yeah, congrats on the wee-one! Name and specs?
_____________________________________________ I don't roll on Shabbas, dude. Ranger truggy, 4.0, np435/205, spooled D44/9", Duff arms & 4-link, Bilstein coilovers, full hydro steer, and 37" Iroks My build: /forum/ford/991042-rockstar-ranger-build.html |
#135 (permalink) |
Member # 46318
Pressley Ann Day Thomsen, 7lbs 7.8 ounces, 19.5 inches long. She joined her big brothers Cohen Allen Cash Thomsen, and Rhyker Kurt Rush Thomsen
#139 (permalink) |
Member # 187456
Awesome man, congrats!
#140 (permalink) | |
Member # 46318
Thanks for all the kind words guys!
. I don't even know what it is. I'm pretty sure it is a late 30's to early 40's Ford. I really should be building something that can fit the entire family. I might put a bench seat in the 79 Ford so that I can fit 3 in that, then 2 can fit in Ol' Skool. Now I need a trailer big enough to fit both rigs on....
#141 (permalink) |
Member # 46318
Here are a few pics. Progress has been slow due to being so busy. I am going to need to remove some of the inner lip of the frame so that the shackles can swing freely. This will then weaken the frame, to fix this, I am going to build a crossmember out of 1/4'' plate that will tie each side of the frame toghether, it will then be notched for the shackles. I will then box the frame where the shackles are also. If you guys can think of a better solution, I am all ears.
I modified the front end so that the superduty springs would work. [IMG] [/IMG]On it's own weight....sort of [IMG] [/IMG]
#142 (permalink) |
Member # 46318
BTW, does anyone know what motor mounts I will need for the 429 to bolt in? This frame was set up for a 7.3 IDI originally. If all else fails I will just fab some out of poly bushings...Here is a pic of the engine crossmember for reference.
[IMG] [/IMG]
#143 (permalink) |
In the garage
Member # 41068
Congrats on the kiddo!
As for the motor mounts....I would GUESS that year of truck came with a 460, those are the ones I would try first.
Tow rig build: 1997 F350, Powerstroke, 4wd conversion Crawler build: 1990 Ford Ranger Truggy Daily driver build: 1965 Chevy |
#144 (permalink) |
Member # 46318
Well here is what I came up with for the shackles. I will box the frame in that area. I will also add some gussets to the sleeve.
[IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
#145 (permalink) |
Member # 46318
I got the rear axle and and springs that I will be using removed from the parts truck tonight.
[IMG] [/IMG]Got the front suspension buttoned up, sans the frame boxing. I want to be able to cycle the suspension before I box it in, I might need to do a little more notching. [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
Project Ol' Skool '37 Chevy: http://www.pirate4x4.com/forum/showthread.php?t=1049898 1979 F-350 build: http://www.pirate4x4.com/forum/showthread.php?t=855113 Last edited by AllGoNoShow; 04-18-2012 at 09:24 PM. |
#146 (permalink) | |
Cactus Farmer
Member # 168243
The truck that the frame half came from was a '91 F-250 IDI if I remember correctly.
-Dave Last edited by Dr.Danger; 04-19-2012 at 12:35 AM. |
#147 (permalink) |
Horsepower Junkie
Member # 173427
I think I would have just added a spacer between the spring eye and the inner shackle to push it to the inside of the frame so it doesnt have go through the frame. Then the bushing sleeve in the frame could be longer so when you box the frame it will put it in double shear.
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress The Making of a Turd: Huff's Green Turd |
#148 (permalink) |
In the garage
Member # 41068
Good idea. What was the application for the poly bushing?
#149 (permalink) |
Member # 46318
Dr Danger...That's good news!
Huff...everything is in double sheer, the shackles are set up just like any other application, except they go through the frame. JTR...These are the ones I used http://www.barnes4wd.com/product_inf...oducts_id=2360
Project Ol' Skool '37 Chevy: http://www.pirate4x4.com/forum/showthread.php?t=1049898 1979 F-350 build: http://www.pirate4x4.com/forum/showthread.php?t=855113 Last edited by AllGoNoShow; 04-19-2012 at 07:28 AM. |
#150 (permalink) | |
Horsepower Junkie
Member # 173427
Carry on!
