Ford Dana 44 knuckle swap? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-06-2012, 06:39 PM   #1 (permalink)
Member # 206973
Send a message via AIM to Built_Ford_Tough_757
I have a 44 from a 1979 Bronco (5lug), someone on craigslist has a dana 44 heavy duty 3/4 ton axle from a 1978 (?) F250 (8lug) flat top knuckles. Will they swap and still keep a good allignment?
Built_Ford_Tough_757 is offline   Reply With Quote Quick reply to this message
Old 03-06-2012, 10:12 PM   #2 (permalink)
Member # 213270
I just did the opposite,swapped out the knuckles from late 70's 250/to a 1/2 ton 44 5 lug pattern every thing works great.I'm also selling all the 8 lug components if your interested.shoot me a pm.
sarsvolta is offline   Reply With Quote Quick reply to this message
Old 03-08-2012, 12:01 PM   #3 (permalink)
Member # 61938
go over to Fullsizebronco.com this has been covered alot with what works and doesnt.
lots of guys run chevy stuff to go 8 lug with that housing.
94 Bronco 5.8/E4OD 6" Stage II 35" BFG
4.88's / Front Aussie/ Warn HS9500I
kemicalburns is offline   Reply With Quote Quick reply to this message
Old 03-09-2012, 10:37 AM   #4 (permalink)
Member # 142138
Send a message via Yahoo to crash-harris
I agree with the last statement. It's been covered A LOT over there. Solid D44's can have the knuckles swapped no prob. You don't even need the knuckles to swap to 8 lug though, just everything from the spindle out. (Most guys convert the TTB to 8 lug with chebby stuff). Most use a custom DOM steering setup.
Bruiser - 1990 Ford F150...barely...EFI 300 Big Six, Converted to 4x4, Undergoing 1 Ton SAS.
crash-harris is offline   Reply With Quote Quick reply to this message
Old 03-09-2012, 10:44 AM   #5 (permalink)
Member # 79509
Whats the goal with the swap... simply to convert to 8 lug? I'd just swap 10B 8 lug outers on and call it a day. Besides, the jury is still out on F250 knuckles being true flat tops. Check out Mr. N's D44 page on that.
Also, pretty sure you have to swap knuckles when doing Ford 8 lug outers, Something about the caliper not fitting the knuckle.
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 03-09-2012, 05:27 PM   #6 (permalink)
Member # 206973
The deal was I found the 1979 Bronco axle for $100 on craigslist. I bought it hoping I could re-sell to get a dana 60. Didn't happen as everyone thinks they are worth $1000 here. So I posted on CL again looking to see if someone wanted to trade 8-lug for 5-lug patterns. Someone replied back with a 1979 F250 knuckle set. He was installing that axle in a older jeep so he wanted the 5 on 5.5 pattern. So we met at his house, useing a level, we saw both knuckle sets where the same top to bottom level. Swapped everything we needed to make it work for both of us. Including knuckles, spindles, hubs, rotors, calipers, caliper supports, locking hubs. I too plan on using DOM tubing for the steering and track bar linkage with some Ebay Hiem joings/bungs and mis aignment spacers
For the steerig, I'm thinking about making a new knuckle to knuckle link that will bolt under the steering arms and have the drag link mount above the knuckle to knuckle / steering arm on the pass side knuckle. Deleting the need for the 3 studded steering arm.
Should one axle be wider than the other on my truck, nothing a wheel spacer can't fix.
What do you'll think?
Old 03-09-2012, 05:47 PM   #7 (permalink)
78bronco460's Avatar
Member # 9152
GM knuckles-out is the answer.
A sword never kills anybody; it is a tool in the killer's hand.
Lucius Annaeus Seneca
78bronco460 is offline   Reply With Quote Quick reply to this message
