205 id - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-12-2012, 05:57 AM   #1 (permalink)
Pokeman's Avatar
Member # 157355
205 id
google and PBB search gave me nothing on how to read the tag. picked this up and am hoping to use it behind my 302 with a c6.
is the serial the date?
Is this a C6 bolt up?
Originally Posted by Mercedesrover
Seriously, there are cats shitting on your floor dude.
Minimal mech. knowledge, overly ambitious
Pokeman is offline   Reply With Quote
Old 03-12-2012, 06:00 AM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
yes the serial is the date 7/12/78
a quick google image search should tell you if its a c6 pattern.
trkklr77 is online now   Reply With Quote
Old 03-12-2012, 11:06 AM   #3 (permalink)
Pokeman's Avatar
Member # 157355
not working out. no decent pics that have helped
Old 03-12-2012, 11:16 AM   #4 (permalink)
Member # 98550
I'd assume so. D8 = 1978 and I'm pretty sure that was the only auto that was bolted to 205s those years.
Do you have the trans output shaft too?
hart7290 is offline   Reply With Quote
Old 03-12-2012, 11:30 AM   #5 (permalink)
Pokeman's Avatar
Member # 157355
googled the number on the adapter, D8TP - 7A040 - AA. It's for a C6.
Old 03-12-2012, 08:48 PM   #6 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
come on dude.
the FIRST result for "c6 tail housing" google image search
http://www.fordification.com/tech/schematics_g.htm
its explodes for ALL OF FORDS TRANS AND TCASES!!!!!
this was the image that shows up in the search, the first image.
http://www.fordification.com/tech/images/c6_03.jpg
Old 03-12-2012, 09:00 PM   #7 (permalink)
Cactus Farmer
Dr.Danger's Avatar
Member # 168243
You need this. It's not just a bolt her up and go type of deal. You get to tear down the trans and replace the 2wd output shaft with a 4x4 shaft. It's usually easier finding a whole 4x4 transmission.
-Dave
Dr.Danger is offline   Reply With Quote
Old 03-13-2012, 06:56 AM   #8 (permalink)
Pokeman's Avatar
Member # 157355
I sold a 2wd c6 that came with a 302 last week. I am hunting for a small block 4x4 c6.
Old 03-13-2012, 08:19 PM   #9 (permalink)
Member # 93013
Keep in mind there are 2 different 4x4 C6 tailshafts. The long '79 and prior that works with the 205. And the late '80 and newer short shaft for the chain drive transfer case.
As far as I have found, there are no factory long shaft small block C6 combos. You have to build one out of a '70's 4WD C6 (big block of FE bellhousing) transmission and put that into a small block (any year) C6 case.
broncobowsher is offline   Reply With Quote
Old 03-13-2012, 09:55 PM   #10 (permalink)
Member # 98550
I've never tried it first hand but why wouldn't a 205 fit on the short shaft c6? Shifter clearance issues?
Shurly there's some guys with later 80s trucks that have swapped in 205s
Old 03-15-2012, 05:18 AM   #11 (permalink)
Pokeman's Avatar
Member # 157355
anyone?
Old 03-15-2012, 02:06 PM   #12 (permalink)
Member # 38200
I've read that a short shaft C6 - 205 combo will put the driveshaft in the trans pan rail. Just what I've read, no personal experience.
I have a regular long shaft C6-205 mocked up in my Bronco frame. Even that combo looks like it could get a little tight with a CV joint.
Quick & Dirty is online now   Reply With Quote
