quick weight question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-01-2012, 08:40 AM   #1 (permalink)
150
crawler
150's Avatar
Member # 167647
trying to decide on spring rates for my coilovers but I cant find what the front end of my truck weighs anywhere and dont have a scale to go to.
Anybody happen to know what the front end of their half ton truck weighs? mine is a 1989 f-150 with a 302. if anybody has any close guesses that would be great.
1989 f-150 dana 60 front, 10.25 rear. 3 link with coil overs out front. chevy 63s double shackled out back. bobbed bed. rollin on 37s
the build up of ^ truck /forum/ford/1015047-project-89-f-150-a.html
150 is offline   Reply With Quote
Old 05-02-2012, 08:22 AM   #2 (permalink)
Member # 113388
The front of my 86 f150 with a I6 motor weighed in at 2,940lbs. Front corner sprung weight was 1,245lbs
weswes01 is offline   Reply With Quote
Old 05-02-2012, 03:32 PM   #3 (permalink)
Member # 217722
do you know the spring rate of the coils that are on there now????
http://www.planetspring.com/pages/co...calculator.php
should help you decide on how much your truck weighs, and what rate you need....
prosport33 is offline   Reply With Quote
Old 05-02-2012, 05:21 PM   #4 (permalink)
Member # 113388
I'm interested in what the stock springs are too. Im guessing around 200? I think my pro comp 4in lift coils were 250
Old 05-02-2012, 06:13 PM   #5 (permalink)
Member # 217722
just for reference.
the ultimate adventure f250 ranch truck that ORD built uses 300 ppi overall rate, for the coilovers.
im also using the same on my obs f350.
id say about 200ppi on your f150 would be pretty good.
Old 05-02-2012, 06:13 PM   #6 (permalink)
Member # 217722
holy fucking huge pictures batman
how do you resize them?
Old 05-02-2012, 06:32 PM   #7 (permalink)
Member # 113388
Iv always loved that truck. Is it diesel?
Old 05-02-2012, 07:17 PM   #8 (permalink)
Member # 217722
yep, 7.3
apparently it has the dynatrac pro80 up front and the stock sterling rear
and if i read everything correctly, it weighed in at 10k lbs. goin down the trail
ive only found like 1 youtube video where you can see it for like 5 seconds.
im still looking for the 2009 UA dvd. hopefully there is more footage of it on there.
Old 05-02-2012, 07:44 PM   #9 (permalink)
150
crawler
150's Avatar
Member # 167647
well i just kinda guessed that the corner was around 1100 lbs. and i ended up with about a 140 ppi rating. And i got 200s over 400s. Hopefully it doesnt turn out too soft
the build up of ^ truck http://www.pirate4x4.com/forum/showthread.php?t=1015047
Old 05-02-2012, 08:09 PM   #10 (permalink)
Member # 217722
its hard to say, it depends on how you want it to ride..
you can get away with a softer spring rate if you have firmer valving, and mount the CO's further out towards the inner C's or even on top of them.
did you get 16'' or 14''
im guessing you didnt use the spring rate calculator to calculate the spring rate thats currently on your truck??
Old 05-02-2012, 08:56 PM   #11 (permalink)
150
crawler
150's Avatar
Member # 167647
ya they are going to be mounted as far out as i can get them on the axle. And i want it to be pretty soft so I think i will be ok. I might go a little higher rate on the upper or lower.
And i ended up getting 14s
