Member # 14848
1978 F150 ignition troubles... Please help!!!
I am hopeing one of you has run into this before. I have a '78 F150 and it will not start. It was running last night and just calmly sputtered out and died and will not re-start. This morning I was working on it and found that it had very week spark. I purchased a new coil and ignition module (I suspected that it was the module that was giving the troubles anyway) and that cured it-- for about 30 seconds. It ran great and then did the same thing all over. I think that I have a short somewhere that is cooking my ignition module. The wireing under the hood looks good, but under the dash I haven't even started yet. I am hopeing someone could give me some pointers on where to look. BTW after the module dies on me I only have 6vdc at the coil + with DEC shorted to ground. I have no idea why this happens either, because if you disconect the ignition control module then the coil voltage goes back up to ~11.9 vdc right where it should be according to my chiltons. ANy idea whatsoever would be appreciated. I am goint to put a new ignition switch in tomorrow incase there is an iternal short in the old one-- it is getting kind of "loose". Well, help me if you can!
Thanks,
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case 1988 Bronco,in progress |
Member # 3677
The fusible link could have gone out. It is a "stupid ford shit" type of part, I think it connects the alternator to the starter solenoid, but am not positive. If that goes out or breaks you won't get nothin to work no mnatter what you replace.
Rigless... |
Member # 14600
Ford uses a resistor wire to feed it's ignition, it could be getting weak. I believe you can still get the correct wire from the dealer. If not you can always run a straight wire through a ballast resistor of the correct value. Location of the wire and resistance value can be found in the appropriate wiring diagram. The Haynes manauals have excellent wiring diagrams included. The Chiltons are worthless for electrical problems. Hope that helps. Good luck!
Member # 14848
I am pretty sure this is the DURASPARK 1 ignition system and doesn't have a resistor wire... At least that is according to my chiltons-- and you are right Haynes does have much better wireing diagrams, but I didn't want to have to buy the fawkin book too, I am trying to get rid of the POS right now and would rather not spend more and more money on it! I guess tomorrow I will break down and get the better manual.
Thanks,
#6 (permalink) | |
Member # 13205
measure resistance of the pick-up coil and it should be 400-800 ohms. Mine was M-ohms. Replaced...took care of it.
True friends will laugh when you hurt yourself. |
Member # 14848
Well, I have it figured out. Turns out it wasn't the ignition sytem at all. My brand new holley carb (about 100 miles on it) evidently went to carbeurator heaven. I can get it running on a dribble can, but for some reason the carb is fawked up. I am taking it back and getting it replaced. Thanks all of you for your thoughts!
Thanks,
