EGR Delete - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2012, 09:55 AM   #1 (permalink)
Whatever Works
JM93LiftedYJ's Avatar
Member # 128472
EGR Delete
1996 F250 with a 5.8.
Had a manifold gasket leak. Bought a new manifold. Cracked the pipe connecting to the EGR. $150 for an EGR. I'm reading all sorts of stuff about an EGR delete. Can I just block off the port to the manifold and the port to the motor? Is it that simple? I also read that I'd have to do "computer work"? This only needs to pass safety since its GVW is over 8000 so I have some leeway there.
Thanks. This is my first Ford I've ever owned. Reading what I can, but this has me stumped. Thanks.
Samurai Build on a Low Buck Budget: The Tin Can
1. NEVER, EVER date a single mother.
Work harder. Millions on welfare depend on you.
JM93LiftedYJ is offline   Reply With Quote
Old 05-25-2012, 10:42 AM   #2 (permalink)
dieselboy740's Avatar
Member # 168108
I your truck has the pressure differential sensor up on the firewall it will set a code. On the EEC trucks it won't as easy my friends truck we welded a plug into the exhaust manifold side and stuck a penny into the intake side gasket and it looks like its still operational but is capped off both sides.
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch
'90 f-250 project, boat sides, 3/4 link, cage etc
'91 Volvo 940se holset turbo, olive drab, lifted rally car
dieselboy740 is offline   Reply With Quote
Old 05-25-2012, 03:44 PM   #3 (permalink)
brewchief's Avatar
Member # 71185
RJM injection has an EGR eliminator plug for the computer as well as block off parts, from what I understand his customer service is lacking but everyone seems to get there parts sooner or later.
brewchief is offline   Reply With Quote
Old 05-25-2012, 05:01 PM   #4 (permalink)
Whatever Works
Member # 128472
While the only option for 1996 and newer Fords is a custom tuned chip for the computer.
http://www.rjminjectiontech.com/products/egr-eliminator
Dad found the parts for $125 or so I guess. meh
Thanks guys.
Old 05-26-2012, 12:53 PM   #5 (permalink)
Member # 64075
Lots of talk of this very subject over on Fullsizebronco.com. Fordfuelinjection.com is another helpful site Call Ryan he'll get you going.
1tonF100 is offline   Reply With Quote
