Member # 81455
9"-sterling hybrid axle question
would like to take a 9" housing and third. remove shafts and axle ends. then take a sterling 10.25" semi float (8 lug) remove those ends and axles and install on the 9" housing. this gives me 35 spline and eight lug. obviosly i am being a cheap sob here but will it work? something obvious that i am missing?
thanks |
Swamp Crawler
Member # 63692
They make a 10.25 Seni Float?? I thought all of those were full floaters.
Can you post up some pictures of the Sterling? I'd like to see what the Semi Floater axles look like.
It's........It's.......SOLD ![]() ![]() /forum/general-4x4-discussion/781848-blases-k-o-r-e-chassis-build-up.html http://www.jak4x4.com |
party wagon
Member # 202878
ive seen the sterling 9.75" semi float, but never a 10.25 semifloat...
then again i have not been around vehicles that long
jeep is getting a new home! NEW PROJECT ON THE HORIZON!!! E-350 12 valve cummins, 2006 F350 axles, 6" lift and 37's ... |
Fawkin Fordhead
The semi float 10.25 is relatively uncommon, but under 8500gvwr F250's from 85-96 could be had with them. The last one I saw was a 92 5.0/5 speed 2wd F250
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
#5 (permalink) | |
Member # 81455
thanks again |
Fawkin Fordhead
Yes, it is a C-clip axle.
#8 (permalink) | |
Marines deleted mine
Member # 84339
![]() I'm pretty sure the 10.25 shafts are gonna be longer than the 9" shafts.
The definition of irony: http://www.pirate4x4.com/forum/attac...1&d=1334801294 Yeah, Janelle R Becher is a cunt
Member # 219497
you might run into a problem with the spline pressure angles too, as far as i know the most sterling are 45* and most 35sp. 9" carrier/lockers are 30*, i may be wrong but something to look at.
#14 (permalink) |
Member # 123702
I got a 10.25 SF in the rear of my truck came out of an 88 250 351W C6 truck. I welded the spider gears together and then just got a piece of 1/4 plate and cut a few knotches in it for the teeth and welded it in on one side so i could still get he c-clips in.
![]() ![]() Has held up fine so far, only got a 300 I6 with 40s though
83 F-250 300 4spd Welded 40" Gateways 77 F-250 Super Cab Future Tow Rig Ford 300 I6 = Greatest Motor Ford EVER Made |
#15 (permalink) | |
Member # 70068
In Memory of: '04 Rubi Sunray 9s ....sitting low Now: '04 LJ on Tons, gotta get it lower Last edited by jeeps4fun; 06-08-2012 at 08:11 PM. |
#18 (permalink) | |
Member # 208306
#21 (permalink) |
Member # 46175
I guess I don't understand why it would be "badass"? It seems like a ton of work/money for very little gain of ground clearance and weight savings.
I am really curious how they welded the axle so it was concentric one end to the other. The 10.25/10.5 I have worked with always have a left hand threaded spindle on the driver side. It would be cool to get a full float jig for a left hand thread. I am guessing that they got it just close enough. Is there a build thread for that?
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST Specializing in Axles and Transfercases |
#22 (permalink) |
Moderhater
Member # 16980
duh- this is simple
![]() 2 1" drain plugs in the back of the diff to put the c clips in via magnet ![]() and the 9" housing im assuming is gonna have to be beefed up as well (flex)
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf |
#24 (permalink) |
Member # 68844
The only true advantage I can see is the quick change capability for the gears. Having full float outers would make that go even quicker. You would need the same kinda thing for the front, but pulling front shafts is not that quick.
#25 (permalink) |
Member # 138794
Start Here I don't see much of a point unless run high pinion but looks cool....
