my project - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-07-2003, 01:17 PM   #1 (permalink)
Driven by hate
Danger Ranger's Avatar
Member # 1234
my project
What do you think? It’s obviously not done and nothing is permanent yet…
That upper link will be remade out of round tubing so that the Johnny joint isn’t maxed out. Square is all I had left and I wanted to get something tacked up.
You can check-out any time you like, But you can never leave!
Danger Ranger is offline   Reply With Quote
Old 01-07-2003, 01:18 PM   #2 (permalink)
Driven by hate
Member # 1234
another
Old 01-07-2003, 01:19 PM   #3 (permalink)
Driven by hate
Member # 1234
and another
Old 01-07-2003, 01:19 PM   #4 (permalink)
Driven by hate
Member # 1234
last one
Old 01-07-2003, 01:28 PM   #5 (permalink)
Driven by hate
Member # 1234
I probably should add, the eng crossmember will be going bye-bye and I will be doing full hydro for steering.
Old 01-07-2003, 01:49 PM   #6 (permalink)
Member # 848
Very nice...... how do you keep the inner body so straight
So the front "A" is supposed to work like your trackbar, but isn't it going to bind on compression/droop of the whole axle....such as a jump. On droop, the radius arms will want to pull the axle toward the back of the truck, and the "A" will want to pull it forward........compression just the opposite....did I miss something?
SNOWTREK.org
Nobody is online now   Reply With Quote
Old 01-07-2003, 01:50 PM   #7 (permalink)
Member # 848
Nevermind, I see how the "A" will extend.... nice work!
SNOWTREK.org
Old 01-07-2003, 02:27 PM   #8 (permalink)
Driven by hate
Member # 1234
Why? you want the inner body? it's gonna get sawzalled in the near future
Old 01-07-2003, 02:39 PM   #9 (permalink)
Member # 848
Nahhh, mines getting the sawzall too. It's about to completely fall off anyhow
SNOWTREK.org
Old 01-07-2003, 02:59 PM   #10 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Copycat!
mine is about the same right now (the links) i just need to order the Rubicon express joints
Mark
welndmn is offline   Reply With Quote
Old 01-07-2003, 03:03 PM   #11 (permalink)
ASH
ASH's Avatar
Member # 15839
How did you figure out how tall the center link mount needed to be? Nice job, I thought it would be to hard to figure out all the BS with a front mounted wish bone, but you make it look easy.
ASH is offline   Reply With Quote
Old 01-07-2003, 03:10 PM   #12 (permalink)
Driven by hate
Member # 1234
Originally posted by welndmn
Copycat!
Got pics Mark? I didn't know you were doing this too. I originally got the idea from a guy who doesn't even go near here (the pirate board that is)
Old 01-07-2003, 03:14 PM   #13 (permalink)
Driven by hate
Member # 1234
It’s not a true wishbone, look closely and you can see the tubing inside tubing. The ‘A’ will become longer and shorter as the axle drops or stuffs. I only have the axle mount that high to leave room for my steering. I’m also considering relocating the whole thing behind the axle and under the motor, would be great for driveshaft and oil pan protection.
Old 01-07-2003, 03:36 PM   #14 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Err nevermind, i missed the A arm up front, yours is better then mine
Mark
Old 01-07-2003, 04:34 PM   #15 (permalink)
ASH
ASH's Avatar
Member # 15839
Oh, ok thanks for pointing out the obvious to me . I thought about using a slip/spline from a 1510 series or bigger driveline, since I have access to it, but I'm lazy.
Old 01-07-2003, 04:45 PM   #16 (permalink)
Member # 144
haha you're a freak Aaron! Now.. why did you go with a front mounted A arm instead of a rear mounted one, given that you're going with full hydro steering? Im curious
That's because you're a pinko fascist. - Haole
I know what antidisestablishmentarianist means
mike is offline   Reply With Quote
Old 01-07-2003, 05:08 PM   #17 (permalink)
Member # 1408
Send a message via AIM to RockRanger
Looking good Aaron. Have one Q though I noticed the long arms that go towards teh middle of the truck that the one on teh driverside goes to the bottom of the axle tube and teh one on teh pass side goes to the top of teh axle tube. Think this will cause any problems or benefits to this?
Matt
RockRanger is offline   Reply With Quote
Old 01-07-2003, 05:09 PM   #18 (permalink)
Driven by hate
Member # 1234
It was easier to mock up for now, I'm not positive it will fit behind the axle and under the motor... but i'll probably try it anyways. Like I already said though, it would be killer for driveshaft and oil pan protection
Old 01-07-2003, 05:15 PM   #19 (permalink)
Driven by hate
Member # 1234
Matt
Technically it's a wristed arm suspension and I can't think of any logical reason (in my head... haha) that says I can't attach the wristed arm wherever in relation to the axle tube.
Old 01-07-2003, 05:20 PM   #20 (permalink)
Member # 1169
Send a message via Yahoo to Monkeyboy
Tell the truth Aaron the Beer made you do it
It was even more of a turn on when I found out she was doing me to buy baby formula
Monkeyboy is offline   Reply With Quote
Old 01-07-2003, 05:30 PM   #21 (permalink)
Driven by hate
Member # 1234
haha no I made that mistake few years when I first did the 44/9" and it wound up taking me 3 months just locate a d44 with leaf springs bad
So I actually have to refrain from drinking while working now cause then I'd really get nothing done like you
Old 01-07-2003, 05:33 PM   #22 (permalink)
Member # 1169
I get my drinking done just fine, Thank you very much
Old 01-08-2003, 04:12 AM   #23 (permalink)
Member # 4352
I am curious to know where you got the brackets for the "radius arms" to the frame? Setup looks good!
clc900 is offline   Reply With Quote
Old 01-08-2003, 06:55 AM   #24 (permalink)
Driven by hate
Member # 1234
I made 'em
Old 01-08-2003, 05:59 PM   #25 (permalink)
Member # 15110
qiustion
Good job . I cuold not have come up with that and i dont even drink . I was wondering if the A arm is going to hit the cross member . I am prety shure you could fabricate somthing , or cut the cross member . Just curios . I may want to try this one day .
BORN BLUE OVAL
leehall is offline   Reply With Quote
