need Ford 9inch ID help...
okay I found a Ford 9" under an 81 F-100 2wd that has 31 splines and a 5 on 4.5 bolt pattern. I didn't have time to pull the third member to check the ratio, any idea what it is? The tag on the diff only says "WDM ADD 1F17 3 25 9 S311B" which doesn't seem to include a ratio number or ring and pinion numbers anywhere.
I may just need to go back and pull the third....
awshifting.com awshifting@gmail.com |
#2 (permalink) | |
Member # 6708
Re: need Ford 9inch ID help...
The ratio is 3.25:1 and the ring gear size is 9" If it said '3L25 9' then it would have been a limited slip.
'There will be pork in the tree tops by morning!'-Lion in Winter. 'Dear,dear.....what ever shall we do with mother.'-Lion in Winter. "Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson 'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!' Last edited by Alpo; 01-08-2003 at 07:03 PM. |
#5 (permalink) | |
info
Wanna touch it? |
#6 (permalink) | |
Member # 11139
#7 (permalink) | |
Re: Re: need Ford 9inch ID help...
Yes, I did try a search, both on google and here, I spent probably an hour doing it too. problem is, google links to mostly car sites, not trucks, and it's hard to search for 9 inch stuff on here because it won't let you search with "9".
So let it be known: there is such thing as a Ford 9inch with 31 splines and 5 on 4.5!
#9 (permalink) | |
I never said it's from an F-150, it's from an 81 F-100. It is not from a car, since it is bolted under a TRUCK and about 64" wide. And I pulled the shafts and COUNTED 31 splines. And measured the bolt pattern, and compared it to an XJ. THIS IS A FORD 9 INCH WITH 31 SPLINE AXLES AND 5 on 4.5 BOLT PATTERN (yes, I know I'm yelling )now all I need is a 4.11 third...
Member # 11139
F150s and F100s are the same thing. I will say it again, there was never a 5 on 4.5 full size ford truck. I dont know where the rear came from, but it damn sure aint a full size ford truck rear. Just because it was bolted under a truck dont mean it came from a truck. I am glad you found it, but I guarantee it came from a car, and was swapped to the truck. How much you wanna bet you go back and the front of the truck is 5 on 5.5? 31 spline axles came in cars as well, and the width matches closely the rear of Ford full size cars.
Fawkin Fordhead
Don't say it never existed just because it sounds stupid...
Ford in one of it's brighter ideas equipped the 80-82 F100's with power brakes with the car 5 on 4.5 bolt pattern and 31 spline axles, not only do they have funky axles, but, they also have specific brakes, and, up front, they have different rotors, spindles and calipers.... For the F100's last year in 1983, they got the standard 5 on 5.5 pattern and standard issue F150 brakes. Any of you guys don't believe me, I'll bet my 82 manual brake(5 on 5.5 bolt pattern) F100 Chassis with 230 hp 300 I-6 and NP 435 on it... Ah, hell, here's a truck with it: For an early 80's F100, 3.25's are rather low gears, my 82 had 2.75's, and an O/D tranny from the factory, and, I have seen trucks with 2.47's and O/D.. criuse at 70 MPH at idle... LOL This is what happens when you own your own damn fleet of trucks, you get to know useless information... Evan
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
#12 (permalink) | |
Member # 6708
Never say never! Try searching posts from a year ago. This subject is not new. It was settled last year when most (myself included) thought the same way. Eric
'There will be pork in the tree tops by morning!'-Lion in Winter. 'Dear,dear.....what ever shall we do with mother.'-Lion in Winter. "Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson 'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!' |
#17 (permalink) |
Okay, I won't start a new post until I search some, but can anyone give me some tips on how to remove the third member? I got all the bolts off, and the axleshafts out, then I had the whole axle hanging by the yoke and I was jumping on it. Still nothing. I gave it some good sideways whacks too from a couple different directions, trying to loosen it up.
#18 (permalink) |
Member # 6708
did you remove the copper washers that were underneath the nuts?? These will hold things in real well. Next get a thin wide screw driver and gently tap it in between the case and housing to split the gasket.
Eric
#20 (permalink) |
Member # 7884
Actually I've seen THREE different spindles used on the '80-82 F100's.
the '80's had the stamped and welded "beams" (like an '83 Ranger beams)and a unique spindle There was allegedly a "middle" design used on some '81's but don't quote me on this... The basic implication is that only did ford have a "better idea" (FEEL the dripping sarchasm...) but they couldn't make up their damned minds... The later ones had Forged "I-beams" and a different balljoint setup and that later design spindle that is actually the same as the Large bolt pattern F-150 2wd, only the rotor is unique ![]() All you have to do on the '82's with the last design is swap on F-150 rotors with the larger lug pattern. One of the neater possibilities is that the balljoint arraingement on the last setup has the same balljoint spacing as the Forged I-beam 2wd '84-88 Rangers. Think about those 11" rotors on a 2wd Ranger ![]() Hell I wanna do it to my little trash hauler just to se if it can be done ![]() AllanD |
#21 (permalink) |
Fawkin Fordhead
Alan: My 80 F100 has forged beams with kingpins(spindles and brakes are 79 issue)... Mind you, it's a manual brake 5 on 5.5 truck... My 82 has the stamped steel beams, also, a manual brake truck...
I haven't been close enough to an 81 to crawl under and inspect the front end yet, But, I wouldn't be suprised to find something alltogether different. Evan
