bw 1356 doubler - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-20-2012, 10:09 PM   #1 (permalink)
trial and error
whiterunner27's Avatar
Member # 107096
bw 1356 doubler
I like the bw t-case because they are tough as shit and under rated, so i've done some research regarding the doubler options. Behemoth Drive train is looking pretty good considering not alot of people do a kit like this. Has anybody used one of these units and how well has it held up?
cowboy up
"life's alot tougher when your stupid" - John Wayne
1988 Ford F-250 Diesel, front hp kp 60 w/ 4.56 and detroit, rear sterling 10.25 w/ 4.56 and detroit, bastardized suspension, 12k smitty, cm ss flat bed, 38" ssr's
http://www.pirate4x4.com/forum/ford/...bler-tech.html
whiterunner27 is offline   Reply With Quote
Old 07-21-2012, 10:09 AM   #2 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
There's a few threads on here regarding the behemoth doubler. Ppl say it blows as far as material used and it's not very well thought out. IMO.
On the other hand. Check out Duffy's new box4rocks that uses the planetarys from various cases. Pretty sweet Idea.
Sent from my Droid
jeep is getting a new home!
NEW PROJECT ON THE HORIZON!!!
E-350
12 valve cummins, 2006 F350 axles, 6" lift and 37's
FordX4-offroad is offline   Reply With Quote
Old 07-21-2012, 08:44 PM   #3 (permalink)
jgalvin44102's Avatar
Member # 177804
I have had one of the Behemoth Drivetrain kits in my Bronco for about 7 months now, it works great! He has done a redesign and is using a new case now instead of the hack and wack versions.
Jim
jgalvin44102 is offline   Reply With Quote
Old 07-22-2012, 06:22 PM   #4 (permalink)
Rockcrawler_101's Avatar
Member # 11955
If you got the room length wise you can just cut the side of bw and build an adaptor. I did this almost 7 ago. Never had any issues. Got a 351 with 44 tires
48 willys pickup on 1 tons, 5.8L and 44's. 01 ford superduty 4x4 6 speed.
Rockcrawler_101 is offline   Reply With Quote
Old 07-22-2012, 11:11 PM   #5 (permalink)
trial and error
Member # 107096
input and output compatible?
cowboy up
Old 07-23-2012, 07:11 AM   #6 (permalink)
party wagon
Member # 202878
the input on the 1356 is 31 spline.
the output is also 31 spline on the slip yoke 1356
it will be very long, but you can make an adapter and just slide the two together without a new shaft.
not sure if thats what you were asking.
E-350
Old 07-23-2012, 07:15 AM   #7 (permalink)
Member # 17313
Yours was the inspiration for mine.. Ive got a good 6 years on mine..
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote
Old 07-23-2012, 08:04 AM   #8 (permalink)
party wagon
Member # 202878
jrod and rockcrawler, how long is your front shaft? estimate.
E-350
Old 07-23-2012, 08:12 AM   #9 (permalink)
trial and error
Member # 107096
Got any photos?
cowboy up
Old 07-23-2012, 09:14 PM   #10 (permalink)
Member # 11955
here are two links to the build
http://www.broncoii4x4.com/forum/vie...w+1356+doubler
http://www.pirate4x4.com/forum/showt...doubler&page=2
The front drive shaft is around 65 inches but i also pushed my front axle forward. The rear is only 17 and my wheel base it 117 if i remember correct.
here is a pic of the rig now. Used to be a bronco II
Old 07-23-2012, 10:32 PM   #11 (permalink)
trial and error
Member # 107096
just read the build on the bii forum, Im doin what you did. I'll post pics when I get the time to build i, thanks for the info.
cowboy up
Old 07-23-2012, 11:50 PM   #12 (permalink)
Member # 11955
Just make sure to cut outside the ribbing on the t case to make for more surface area for it to seal up. I redid that sense mine leaked before. After doing that i have never had a leak.
Old 07-25-2012, 01:14 PM   #13 (permalink)
Member # 150796
Hmmm ... this has got me thinking now ... there are a couple electric-shift 1356s I can get my hands on ... maybe I could try my hand at building an electric doubler haha.
Thanks for the info on this, I would never have thought to stack a pair of 1356s.
'92 F150 XLT XCSB - 5.0 M5R2, 31"s - Stock w/nickel-n-dime junkyard upgrades.
Daviticus is offline   Reply With Quote
Old 07-25-2012, 08:04 PM   #14 (permalink)
Member # 17313
as a long box pickup, both front and rear were 47 3/4"
After i shortened it, and linked it, and put in 1 tons.. I'm not sure
