Member # 224581
1988 Ford SAS
Beginning:
![]() TTB Lift kit installed, shackle reversal in the rear: ![]() Donor truck: ![]() Extended radius arms: ![]() Drop radius arm mounts: ![]() Used the TTB lift springs and welded a bolt to the lower spring cup ![]() Boggers back on: ![]() Made the '88 steering work for a while, but it was pretty loose: ![]() ![]() Modified the steering out of a '78 to make it fit better and it drives SMOOTH now:
FORD: For Off Road Driving |
Member # 168167
soooooooo glad you changed that horrible steering setup.
pretty strait forward axle swap not to fancy but it will work. i would stock up on spare axle shafts. they are not going to last long with a heavy truck and boggers. but just a heads up some people might put the drop radius arm mounts in the fail thread. and i hope you welded that bolt on real well
"Watch this and hold my beer" |
Alaskan Wheeler
Member # 44053
Guessing stock length pan-hard rod (or wrong length). Both springs will bow a bit and people build "shim" kits to fix that. All his bow is on one side.
If you buy a cheap taper tool, you can retaper the knuckles and put the tie rod on top. It WILL work even better.
It only take two things to fly: airspeed and money. 71 GMC BUILD: http://www.pirate4x4.com/forum/showt...slow+gmc+build |
#5 (permalink) | |
Member # 224581
I actually took the bolt and cut the head off, drilled into the dish and a short ways into the top of the radius arms, then threaded the bolts about 3 threads in and then welded it so I'm PRETTY sure I'm good on that one. Actually, the frame is bent outward on that side... The ttb axle was not centered because of it. When I installed the solid axle I centered the axle and now the frame rail is over a little further than I wanted it to be. I'm working on a solution to it, just haven't come up with one quite yet...
I hope you are very confident in that bolts attachment, I have seen that exact setup fail spectacularly after a couple bad bounces on the trail
Sent from my Galaxy Nexus using Tapatalk 2
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... [URL="http://www.pirate4x4.com/forum/showthread.php?t=853402&highlight="]Build[/URL] |
Member # 224581
I have been on many-a-trail since and haven't run into a problem. Thanks for the info, though, I'll look forward to it on other threads
#8 (permalink) | |
Member # 157081
Alaskan Wheeler
Member # 44053
Member # 104270
So you raped a 70's ferd to SAS an 88?
Fueled by Hate, caffeine, and sometimes whiskey. My Junk. http://www.pirate4x4.com/forum/showt...229&highlight= |
#12 (permalink) |
Member # 104270
I stand corrected!
#14 (permalink) |
Member # 224581
That has been on my mind since day 1 of the build, It's definitely something I'm working on. The only reason I stuck with them initially is because they flex a li'l bit better than older 1/2 ton springs
