Member # 8402
Can a C4 hold a 302?
Is a C4 going to hold against a 302 or should I continue to search for a C6? I can get a good deal on a C4 otherwise I wouldn't even consider it. Any idea how much hp and torque a stock C4 is suppose to hold? It is from a 85 Bronco with a 351 motor
Inviscid Motorsports #9009 Thanks to; Ironman Offroad - Motorcity Machines - Branik Motorsports |
Key words are "stock 302". Now throw in the extrem use that you are going to put it through. I would keep trying to find a c6 but that is me.
[url][SIZE=5]www.tinbenders.org[/SIZE][/url] [URL=http://www.tinbenders.org/jamboree/2006/products.php]Get your TIN:skull:BENDER Merchandise HERE [/URL] |
if it has any serious power going threw it i would have someone build it to take it. i know a few racer guys who have put 4-500 hp through them. but they did build it to handle it. and if you are putting it behind some serious power c4 or c6 will need to have someone take a look at it to make sure it will hold up
Member # 16173
I have a freshly built C-6 w/ less than 500 miles. It's in a 66' bronco. If you're interested let me know, I'm in the process of changing to an AOD and need to sell it soon. It is a short shaft C-6 and includes the adapter to a NP205.
Member # 8941
I run a good 300 horse past my c4 as a daily driver and as a crawler. It has yet to fail me. Clutch packs just went bad. But thats no big deal. No breakage to speak of.
I have never seen such a ruthless bunch of people til i came on pirate... - hawkins1 |
The C6 is great for all out strenght. The C4 can handle plenty of power, I run the over sized clutch packs and have no problems behind my built 351w.
I like the C4 since it is smaller and lighter. The C6 is great if you can give up a little more space and take more weight.
EMS Offroad |
Member # 16271
C4 with a 302
Not only should it hold up it has very good potential if you ever need to "upgrade". There are literally 100's of 5.0streetstrip cars around here in thu good ole southeast running C4's built to various levels. A close friend of mine ran a 306 Vortech aided 5.0 for an entire season with a C4 and had no tranny problems. His block was a Bennett prepped deal dynoed at 525 with the 'charger and a little spray.
Now for the 4x4 content. I run a C4 behind a 395hp 357 windsor, D60s and LARGE swampers! FWIW, KB
KBEBS a few ebs, a few mods |
Member # 8402
ok. Thanks for the help guys. I'll get a C4 or C6, whichever I can find first. Maybe you guys can help me out with this.. I posted it somewhere else but didn't get any help.
The trans is from an 85 Bronco. It has a 351 bolted to the trans right now, but that might not be the stock motor. It is a floor shifter and I don't remember the rear axle. The guy told me it was a C4(but didn't know).... do you think it is a C4, C6 or AOD? Does the AOD use a floor shift or electric column shift? I'm supposed to buy it this weekend if I want it, but I still don't know what it is.
#11 (permalink) | |
Take a look under the thing, if it is a 3 spd the C6 will have a cast in bellhousing. The C4 you will see that it can be unbolted.
EMS Offroad |
#12 (permalink) | |
Member # 8402
