Explorer SAS - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-23-2003, 10:17 PM   #1 (permalink)
Banned
Member # 11585
Explorer SAS
Trying to plan my friend's Explorer (he's a little slow... evidently I'm the smart one? what's up with that?). We are going to do a SAS on it, and we can get a Jeep Wagoneer for free. Would those axles work?
I am guessing that it has a d30 front and d44 rear, but I wouldn't swear to it.
Two Dogs F..king is offline   Reply With Quote Quick reply to this message
Old 01-23-2003, 11:11 PM   #2 (permalink)
Member # 7303
98% of all Ranger type folks will tell you not to waste your time. How many Jeep people upgrade the D30 to a D44 for strength? The Explorer weighs more then a Jeep as well.
That said, I know of a person who is going to attempt it (he has his own fabrication business though), and I plan to do it with my BII.
All the same Buellshit to me.
'04 Honda 1000RR - daily driver
'59 VW - Long term toy
'00 Buell X1 - #1,653 stunna
'88 Ford Bronco II - Trail slut
'00 Buell Blast - Power is not an option
'04 Honda Shadow Aero - wife's daily driver
'04 - Chrysler PT Cruiser - puppy transportation
Sidewalk is offline   Reply With Quote Quick reply to this message
Old 01-23-2003, 11:23 PM   #3 (permalink)
Member # 4243
Waggy axles sound like a whole lot of work compared to EB....
unless you just want to stick the Explorer body on the Waggy frame
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 12:26 AM   #4 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
I think Wagoneers come with Dana 44s front and rear. You could use the front diff, the pumpkin is on the correct side but it is a low pinion. A better idea would be to cut down a reverse cut Dana 44 from a Ford fullsize.
Don't swap a Dana 44 in place of the 8.8" rear, that is a step backward.
Go here for more info: www.explorerforum.com
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 12:43 AM   #5 (permalink)
Dustin Smith's Avatar
Member # 11139
It depends on what year waggy, as pre-79 uses pass. drop, and post 79 uses drivers side. Some early, 70-72??, did use a dana 30 front.
Dustin Smith is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 03:52 AM   #6 (permalink)
Member # 10063
The Waggy axle can work with some fabricating
Easiest axle to use is the early Bronco D44. Its already setup for coils, as is the Explorer. The trackbar mount is the only thing that really needs to be fabbed up on this setup.
The Explorer has a fairly stout Dana35 front axle already. A Dana30 is a step backward here, also (Many say the simple fact it being SA instead of TTB is an improvement. I, personally have found this to be only slight).
The Explorer 8.8 rear is plenty stout for even 38s with the V6. Doing anything but throwing a Detroit in it would be wasting money. Its a great axle.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
http://www.supermotors.net/22445
4x4junkie is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 09:47 AM   #7 (permalink)
Danger Ranger's Avatar
Member # 1234
That's all fine and dandy...
But nobody axe'd what year this sploder is
What if it's SLA
If not today nor yet tomorrow then some other day
Danger Ranger is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 09:53 AM   #8 (permalink)
alx
alx's Avatar
Member # 2414
Send a message via ICQ to alx
also are you goin to use leafs or coils
is there any way for me to just stay in hell ? that way when things get good i wont have to fall so far when the shit hits the fan again.
alx is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 09:55 AM   #9 (permalink)
Member # 4877
Send a message via AIM to Squanto
What if it's SLA
BINGO. Same thing I was thinking. If it's Post-95, good luck sticking a steering box in there!! Pre-95 is no problem.
It's gonna be some work to get those waggy axles set up, but hell, you can't beat the price!!
As long as it's the driver's drop, I'd say go for it, D30 or 44. Like said before tho, leave the 8.8. 31 spline shafts, ring gear is stout, and the post 95 had discs. Damn good axle!
Leafs would be the easiest, esp on the waggy axles. Hell you could prolly just use the leafs that are currently on there!! The D30 maybe a bit smaller then the 35, BUT you get better hubs, and don't have to fawk w/ the alignment every 2 weeks.
Good Luck!
03 Taco, BBP Rock Sliders, and some other junk. The Mall Krawler.
94 Trackick, dual cases, extended wb, 33's, welded rear, flat bed, still under the knife.
Squanto is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 05:56 PM   #10 (permalink)
Banned
Member # 11585
so yall are saying that I need to find a d44 out of a bronco?
I was planning on using leafsprings on it. I thought that would be easier for what we are doing (not having to worry about designing the links and geting the draglink & panhard right, and all that crap). This is going to be a daily driver truck he's going to use for 4-wheeling.
He'll be doing mud, trails, and rocks with it, and is going to be opting for 35's. He is going to use Mud Terrains for driving, and boggers for wheeling. So we need it to be strong enough for that. And he's set on getting an Explorer.
So we need to find a ford d44 (would any other 44's work? Do I just need to find a driver's side drop d44?), right?
He is also planning on putting in a v8, and getting gears and lockers. I am thinking that a 302 should fit in it since it was an option in the explorers. What gears do you think he should go with?
Any other help would be much appreciated. Thanks guys
Old 01-24-2003, 06:03 PM   #11 (permalink)
Banned
Member # 11585
also this is a pre-95. I think that the wagoneer axle is a d44 now that I think about it. It doesn't look like a Jeep Cherokee axle.
Old 01-24-2003, 07:56 PM   #12 (permalink)
Member # 7303
Unfortunately, I am not a Ranger SAS guru (I haven't done it yet ).
A D44 out of a 76-77 Bronco is the best. You can run it with coils using radius arms from an F-150 (someone will correct me).
You can also go ful width. More stability, but it is harder to get around the trails.
Old 01-25-2003, 03:32 AM   #13 (permalink)
Member # 10063
Good Luck!
Hmmm...
Last I checked the D30 (at least any worth considering) HAD NO hubs
Slap a set of the GOOD Warn hubs on it and don't worry about it.
Never had to fawk with the alignment with my Skyjacker brackets.
Ok, back to the SA
The Explorer already has most of whats needed for the coils. You can use the coilbuckets that are there, or swap on the eB ones. Use the radius arms from the Bronco, also.
You can use '79 F-150 radius arm frame brackets, although if you were to build your own, they wont hang down as low.
As said above, you will only be required to fab up the bracket for the trackbar. This ones pretty easy. Use eB coils.
I would think getting all the hangers for leafsprings mounted, and getting the draglink around the springs is gonna be more work, I would think C-wedges for the Ford radius arms couldn't be too hard to put on the Waggy axle. Leafs have been done, though.
There should be a couple writeups at www.therangerstation.com about SASs, also. I think theres one using leafs.
Yes driverside diff is required (unless you want to change the T-case, too).
4.56 for 35s.
Hope that helps
Old 01-25-2003, 09:10 AM   #14 (permalink)
Member # 4225
Send a message via AIM to pavelow
Originally posted by 4x4junkie
Hmmm...
I think he is talking about the dana 30's that came in the 66-70 bronco's. Those had hubs
Wanna touch it?
pavelow is offline   Reply With Quote Quick reply to this message
Old 01-25-2003, 06:03 PM   #15 (permalink)
Member # 10063
Low-pinion, 260X joints, not sure Id say thats one worth considering, but yes, it has hubs
Old 01-25-2003, 11:48 PM   #16 (permalink)
Explorer's Avatar
Member # 1540
This rig has an EB front end with progressive springs and a wristed arm. It works great on the trail and is amazingly smooth and quiet on the road. Just the way Ford should have built it in the first place.
Ford Explorer & Ranger Offroad
www.ExplorerForum.com
Explorer is offline   Reply With Quote Quick reply to this message
Old 01-26-2003, 12:10 AM   #17 (permalink)
Member # 4243
High-pinion early-Bronco D44
That deserves a couple of these:
Old 01-26-2003, 12:19 AM   #18 (permalink)
Explorer's Avatar
Member # 1540
Ok sorry, semi EB a '79 One side was shortened.
Old 01-26-2003, 06:59 PM   #19 (permalink)
Member # 11111
Send a message via AIM to John Deere Ranger
Early bronco's never had High Pinion
1987 John Deere Edition Ranger
Dana 60
Sterling 10.25 Rear
5.0 HO/ZF/NP203/NP205
Secretary of Navy Gideon Wells wrote n his diary that Lincoln
"thought it essential to provide an asylum for a race which he had emancipated, but which could never be recognized or admitted to be our equals."
John Deere Ranger is offline   Reply With Quote Quick reply to this message
Old 01-26-2003, 07:42 PM   #20 (permalink)
Explorer's Avatar
Member # 1540
I think we already settled that...
Old 01-26-2003, 11:32 PM   #21 (permalink)
tdavis's Avatar
Member # 908
Having done a SAS on an explorer/navajo once before.. here's how I would do it again.
1) find a complete d44 front end from a 1978/1979 ford full size bronco. that includes radius arms radius arm brackets, and coil buckets from the bronco
2) cut about 6-3/8" from the long side. check this number - I think it's the right one - you can use a stock axle on the long side then (not f150/bronco)
3) remove all of the TTB crap from the explorer. This includes the brackets, and the coil buckets.
4) order EB, 3.5" lift coil springs.
5) get a wristed radius arm. this will go on the passenger side.
6) order 7-degree radius bushings. You'll need these to correct caster.
7) bolt it all together.
8) at this point, decide on steering, and other crap. The calipers bolt right up - so no need for a change there. The only major change - you'll either need to get spacers with 5x4.5 to 5x5.5 conversion pattern, or replace the rear axles shafts with shafts from dutchman/moser with the correct pattern on them.
There's more, but this gives you a cheap, SAS frontend that's tough, flexes great, and rides like the original factory TTB front end!
I take my zuk out for walks.
tdavis is offline   Reply With Quote Quick reply to this message
Old 01-27-2003, 06:38 PM   #22 (permalink)
Member # 9377
Aquaman we have a EB with full width axles and mine has a 3 link coil rear and lots of other Ideas that might help you out if you wanna take a look at some of our crap.
74 Bronco 351W C6 203-205 ARB 4 wheel disk 3 link . 38.5 TSL SX Super Swampers
MXPAZ is offline   Reply With Quote Quick reply to this message
Old 01-27-2003, 08:33 PM   #23 (permalink)
Banned
Member # 11585
I just might do that. Where are you located?
Old 01-28-2003, 05:23 PM   #24 (permalink)
Member # 9377
I live in Parkville. Most of our crap is over at my buddies house in KCK.
Old 01-29-2003, 06:58 PM   #25 (permalink)
2002 FX4 Ranger's Avatar
Member # 12130
Send a message via AIM to 2002 FX4 Ranger
I am doing an SLA Ranger right now.
We are using a Waggy D44, Rancho 44044 front springs, scout II box, the rest is go as we get to it. You can talk to Rerard on here and see what he tells you. He recently did his 98 SLA Ranger with the same setup I am doing.
2008 F-250 6.4PSD leveled 35" BFG AT's on 20" MB Motoring V-Drives.
2002 FX4 Ranger is offline   Reply With Quote Quick reply to this message
