power steering ?'s
well i guess i should welcome my self to the world of ford power steering. is it normal for the pumps on ford trucks to whine and increase loudness with rpm levels? at idle its not there but when you accelorate it in creases(only noticiable if stereo is off). i think its low fluid due to teh fact it also louder while turning, it does leak and i havent checked it in a while. just bored at school and though tid ask if it coul dbe anything else? thanks guys! jiMMy oh yeah its an 87 F250
RockZombie:68FJ40 LPG350/sm420/d300/d60/d70 |
Member # 882
Yes they suck...
Read that article that welndmn wrote about converting because if yours leaks now you might as well go that route. It will cost you less in the long run. One of mine leaks and when its cold it leaks even more. Its a major PIA. I just have been lazy and not replaced it though.
Ryan Last edited by rpenner54; 11-07-2001 at 01:26 PM. |
#6 (permalink) | |
Well Done Man!
maybe you better go over to www.jeepsunlimited.com
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
Member # 6350
Yes they are lould, yes they are junk for turning anything bigger that 31'a and even then................
Swap to a Saginaw pump and be done with it. Works for me...............................................: )
[url="http://www.bronco78.com"]bronco78.com[/url] [url="http://www.superford.org/registry/?vID=144"]Bronco Specs[/url] [url="http://www.teamalaska4x4.com"] Team Alaska[/url] [url="http://www.outbackchallenge.com"]Australian Outback Challenge [/url] |
#8 (permalink) | |
John Foottit 70 bronco, lightly modded Contact me for your custom Cabinetry Needs [URL="http://www.beniciacabinetry.com"][B]Benicia Cabinetry, Inc.[/B][/URL] |
#9 (permalink) | |
Member # 6350
Well Done Man!
i had the F-250 pump (hell my F250 has the ................F250 pump)
anyway, go tired of it and swapped a sag pump on it, like night and day differance, i show people i cna turn with one finger with my 38's
