c-6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2001, 07:55 PM   #1 (permalink)
Member # 4118
c-6
what are my options for tcases behind a c-6. currently it is hooked up to a 208 with a fixed front yoke. Have chev dana 60 front but no way to swap to transfer case with passenger side drop short of making my own adapter. never worked much with ford always used chev in past. can i use a jeep 300 or 20 or achev tcase somehow help
culero
xmbldx is offline   Reply With Quote
Old 11-11-2001, 09:38 PM   #2 (permalink)
Member # 2139
Send a message via Yahoo to FordPowr
neither the 300 or D20 will work w/o an adapter....Any other fullsize ford T-case will bolt up though.
NP203, NP205 and BW1356 have 31 spline input shaft and 6 bolt round bolt pattern
FordPowr is offline   Reply With Quote
Old 11-11-2001, 10:46 PM   #3 (permalink)
emsoffroad's Avatar
Member # 1802
Send a message via AIM to emsoffroad
If you are into so mods you can replace the input from a Chevy 205 with the ford set-up, then you have to redrill and tap the holes for the Ford setup.
EMS Offroad
emsoffroad is offline   Reply With Quote
