5.0 vs 5.8 swap! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-29-2003, 07:58 AM   #1 (permalink)
JOHNS351C's Avatar
Member # 8282
5.0 vs 5.8 swap!
I found a crack in my 5.0 block that is in my rig and after sourcing out a used 5.0 block A guy pulled up to the shop and asked if I had any use for a 94 5.8 out of a truck. He only wants a couple hundred bucks for it. He did say it has a burnt valve, but the engine it needs to replace is a 87 5.0, will the heads swap over? Also does anyone know the physical dimensions that are different between the two? My truck has the floor built around the engine and if it is much bigger it will not fit.
Thanks for any help,
John
[SIZE=4][COLOR=DarkOrange]Stazworks[/COLOR][/SIZE]
[B]The leader in Custom Double Beadlock wheels[/B]
On SALE NOW [COLOR="DarkOrange"][SIZE="2"][I]20x14's[/I][/SIZE][/COLOR]
Due to NEW tooling we can now build std. 1pc 20x14's, and up to a 20x25's without banding!
[COLOR=DarkOrange]www.STAZWORKS.com[/COLOR]
(715) 333-RIMS,(7467) shop number
(715) 333-7250 office
John Staszak-owner
JOHNS351C is offline   Reply With Quote
Old 03-29-2003, 07:59 AM   #2 (permalink)
JOHNS351C's Avatar
Member # 8282
here is another to give an idea of what space I have.
John Staszak-owner
Old 03-29-2003, 09:02 AM   #3 (permalink)
Member # 11111
Send a message via AIM to John Deere Ranger
302 27-1/2 Inches 20-3/4 Inches 18-3/4 Inches
351W 27-1/2 Inches 23-3/4 Inches 21 Inches
Length width and height
1987 John Deere Edition Ranger
Dana 60
Sterling 10.25 Rear
5.0 HO/ZF/NP203/NP205
Secretary of Navy Gideon Wells wrote n his diary that Lincoln
"thought it essential to provide an asylum for a race which he had emancipated, but which could never be recognized or admitted to be our equals."
John Deere Ranger is offline   Reply With Quote
Old 03-29-2003, 09:26 AM   #4 (permalink)
JOHNS351C's Avatar
Member # 8282
Are the heads interchangable?
So it is 3"wider and 2-1/4" taller
is the height all abover the motor mounts or is some of it below the mounts?
The way it sound it isn't going to work for me
Is the 5.8 that much more powerful? Or can easily get a comparable amount of power out of the 5.0?
John
John Staszak-owner
Old 03-29-2003, 09:51 AM   #5 (permalink)
Member # 1481
heads are a little taller which makes the intake a little wider. you get tq from the 351.
shon
researching my next mistake....
shons b2 is offline   Reply With Quote
Old 03-29-2003, 11:14 AM   #6 (permalink)
Member # 11975
Send a message via AIM to MikeW Send a message via MSN to MikeW Send a message via Yahoo to MikeW
The 302 and the 351 have about the same horsepower, but the 351 has more torque probably cause it has a longer stroke.
MikeW is offline   Reply With Quote
Old 03-29-2003, 06:05 PM   #7 (permalink)
Member # 11111
the height is *I belive* above the motor mounts not below
Dana 60
Sterling 10.25 Rear
Old 04-07-2003, 07:44 PM   #8 (permalink)
Member # 14600
To use the 5.0 heads on your 351 you'll have to have the head bolt holes enlarged. The 5.0 use 7/16" bolts vs the 5.8's 1/2" bolts I'm not sure about chamber volumes though, other than that they'll bolt on.
Oatmeal is offline   Reply With Quote
Old 04-07-2003, 07:47 PM   #9 (permalink)
Member # 14600
shon
It's not the heads that are taller it's the deck heighth thats taller, placing the heads higher and farther apart.
Old 04-08-2003, 08:53 AM   #10 (permalink)
Member # 3959
from the pictures it looks like your 5.0 intake is partially under your firewall - if that is the case, then the 351W will not fit - at least not with EFI - the top of the efi intake will be at least 1 or 2 inches taller than the 5.0.
on the plus side the '94 351 block is a roller block so you can easily use a roller cam.
For the heads, as stated above, you'll need to re-drill the head bolt holes for them to fit - however I would upgrade the heads. The 302 heads are already low flowing heads for a 302, on a 351w they will starve it for air some. For the low dollar route, get a set of GT40P heads and some port work, or a set of world heads. To really wake it up get a set of Canfield 18 degree or AFR 185s.
-Ben
'74 Bronco - some assembly required... one of these years I'll drive it again.....
When did common sense become uncommon?
injectedEB is offline   Reply With Quote
Old 04-08-2003, 02:04 PM   #11 (permalink)
Member # 14135
The 351 heads are the way to go. They fit nicely on the 302. You'll use a 302 intake because the 351 is to wide (as stated above from a taller deck height). You can use the same 302 head bolts but the better route is to get collard head bolts (they have a wider shank at the top of the difference in the hole size of the 351 heads, available through ARP I believe). I put 351W heads on my 302 in my '95 Ranger and they were perfect. It doens't look liek you'll have room for the whole 351W motor though.
saber6 is offline   Reply With Quote
