ignition timing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-18-2003, 09:42 PM   #1 (permalink)
jslater's Avatar
Member # 8243
ignition timing
Just wondering what the factory timing for an early (74') 302 is? I set it 8* btdc. Runs good but need to know if that's correct.
Jay
jslater is offline   Reply With Quote
Old 04-18-2003, 10:09 PM   #2 (permalink)
Member # 13898
Send a message via AIM to HNRYS69
I run around 15-18 degree and love it! I also plugged off the vacum advance if you have one, runs much better at highway speeds... I have heard that older fords have problems with the vacum advances..
- Andy Henry
69 bronco, built 302, C4, BC-3.5in lift, sawzall body lift, 37" MTR's, PTO winch
[url=http://hnrys69.classicbroncos.com/]Click to visit my webpage!![/url]
HNRYS69 is offline   Reply With Quote
Old 04-21-2003, 08:21 PM   #3 (permalink)
Member # 14600
Your 302 will run best with the most timing it'll tolerate. Get the motor nice and warmed up, put it under a load (ie. a steep hill in top gear) advanced the timing till it starts to ping, than back it off a couple degrees. Also, it'll pull away from a stop cleaner with the vacuum advanced hooked up and get slightly better mileage.
Oatmeal is offline   Reply With Quote
Old 04-22-2003, 07:42 AM   #4 (permalink)
jslater's Avatar
Member # 8243
I was going to shoot for 36-42* total but don't think I can get that much. maybe 28-34* total is more reasonable. I am pretty sure 27* total is doable but that means 12* initial. Hope it's ok??
Jay
