9" Question-setting preload/torque when switching yokes - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-04-2003, 09:34 PM   #1 (permalink)
Member # 8483
I am installing new 3rd member into 9"; someone had helped himself to the yoke so I must now reinstall one. Am concerned with torque spec for the pinion nut- How do I properly install without destroying crush sleeve or screwing up preload? This is a daily driver so I need reliability- and I need it back on the road!
Any help would be much appreciated-
TIA
My lug nuts have more torque than your whole ricer motor!
4byford is offline   Reply With Quote
Old 05-05-2003, 05:38 AM   #2 (permalink)
Member # 6708
Done right you must replace the crush sleeve. this is how Ford set preload. By torqueing the nut you set nut torque and pre-load all at once.
Eric
'There will be pork in the tree tops by morning!'-Lion in Winter.
'Dear,dear.....what ever shall we do with mother.'-Lion in Winter.
"Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson
'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!'
Alpo is offline   Reply With Quote
Old 05-05-2003, 08:30 AM   #3 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Ehh, i reuse crush sleaves sometimes, the right way IMO would be to get a Solid spacer and loose the whole crush sleave.
But you need to remove the pinion support (5 bolts) then install the new yoke, off the top of my head, set it to 10in/lbs of rolling torque
Mark
welndmn is offline   Reply With Quote
Old 05-05-2003, 09:24 AM   #4 (permalink)
Member # 17452
If any water/dirt got in when the yoke was pulled then you should remove the 5 bolts, take the pinion support off and lube/replace bearings as required, clean up shims and support and put gasket maker on the case to get a good no-leak seal. If not then all you have to do is remove the oil seal and the yoke washer, outer pinion seal and crush sleeve will fall out in your hands.
Technically you dont need to replace the crush seal if you are reusing the same ring gear, pinion and outer and inner bearings.
Here's how I did mine: Grab your breaker bar (dont use an impact if reusing crush sleeve, once a sleeve is crushed too far there is no other way but to get a new sleeve and start all over) and start torquing the new pinion nut on. With your other hand keep pulling and pushing on the yoke as you tighten it until there is no more free play (cant move the yoke in or out). Now tighten the nut in very small increments like 1/16 or an 1/8 of a revolution. After each increment use your in/lbs torque wrench and try to turn the yoke with it. Repeat above procedure until torque specs are met.
Pinion bearing torque is 6-7in/lbs for used and 13-15in/lbs for new bearings. Set yours somewhere inbetween and call it good.
This is how this n00b set his up. Feel free to critique on how or why my technique may be wrong.
Brick Wall is offline   Reply With Quote
Old 05-06-2003, 04:57 PM   #5 (permalink)
Member # 8483
THANKS
Appreciate the info- Nothing has gotten into the housing, so I am in good shape there.
Brick Wall, I think I will take my chances and go with your technique. I don't really want to pull the pinion support if I can avoid it. I will shoot for 9-10 in/lbs and see how that works.
Now, to find an inch lb torque wrench....
Thanks again!
Old 05-06-2003, 10:24 PM   #6 (permalink)
Relax Coconut!
pacopico's Avatar
Member # 14080
Re: THANKS
Thanks again!
Remember...you need a dial-indicator or beam type...not a click type to check pre-load.
pacopico is offline   Reply With Quote
Old 05-07-2003, 10:14 PM   #7 (permalink)
Member # 6414
Why even bother with the inch pound torque wrench, the sleeves are engineered that once a certain amount of torque is applied to the nut then it is done.
Remove the pinion housing from the 3rd member, slide on a new crush sleeve then your yoke and stick the yoke in a big vice. Get a 250 lb-ft torque wrench and take the nut to 175 lb-ft. It will be right!
78 Ford Bronco & 78 Ford F150
www.dmis.ca
desteurm is offline   Reply With Quote
Old 05-08-2003, 09:01 AM   #8 (permalink)
Member # 13470
This is an assumption that may be correct most of the time but not always. As cheap as a torque wrench is why would you not do it right instead of hoping you did it right.
And yes I have done the setup before and mine required a little greater than the 175 lb-ft to get the preload spec'ed with my ring and pinion setup. I'm glad I went ahead and used the torque wrench.
Hobe is offline   Reply With Quote
Old 05-08-2003, 07:23 PM   #9 (permalink)
Member # 9152
I use my fish scale. I measure 12" from the center of the socket on my torque wrench and mark the handle with a piece of tape. Pull on the handle with the fish scale and each lb. on the scale is a foot-lb. excellent for checking preload.
Why kill them with kindness when you can use an axe?
78bronco460 is offline   Reply With Quote
Old 05-08-2003, 08:23 PM   #10 (permalink)
Member # 18867
IN POUND TOURQE WRENCH WAY TO GO. IF PRELOAD'S NOT RIGHT THEN WON'T WORK. I INSTALLED NEW SEAL AND TORQUED IT DOWN TO 175FTLB MY RING AND PINION WAS HOWLING WITHIN 3000 MILES.
80 F-150 44 solid axle swap 4.56's Detroit's f/r, Wristed arm, Chome Moly steering and much more.
1 tuff truck is offline   Reply With Quote
Old 05-09-2003, 12:50 AM   #11 (permalink)
Member # 16225
Just run a solid spacer with shims like a dana axle. That is what i have and it is way better because if (when) you hit the ds yoke on a rock, you will probably lose your pinion bearing preload, which in turn, wipes out your R+P, over time
toyota crawler
1tonYJ project
dittohead is offline   Reply With Quote
Old 05-10-2003, 06:35 PM   #12 (permalink)
Member # 16408
What is the correct procedure to set up a solid sleeve? Mine from Summit came with an assortment of thin shims, one thick one and the main section. I put the thick one in and the main section, tightened it all up and it seems to be in spec. It can't be that easy, can it?
'78 Ford F250 4x4 SC D70/60, 6bta Cummins (not quite stock!), Southbend CON-O, BHAF, NV4500, NP205.
Force to fit. File to hide. Paint to cover.
Scot is offline   Reply With Quote
