92 Exploder lifter tap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-22-2001, 07:34 AM   #1 (permalink)
Member # 2119
Post 92 Exploder lifter tap
I have a 4l. 92 Explorer and it has developed a nasty lifter tap over the last 20,000 miles. It goes away after about 15min. but if you put your ear up to the hood its still there. The truck has 150,000 miles on it but the motor runs very strong so are the valves adjustable?
How many licks does it tak.... AWWW JUST SUCK IT
wheelinjp is offline   Reply With Quote
Old 10-23-2001, 11:19 AM   #2 (permalink)
Member # 7709
Post
I don't know about the lifters being adjustable, but I have a '92 4.0 Ranger that developed the same thing this past year. I switched to Premium gas and haven't heard it since. May want to try that...
Happyman is offline   Reply With Quote
Old 10-23-2001, 08:16 PM   #3 (permalink)
Member # 7004
Send a message via AIM to asp84
Post
The 4.0L lifter tap is very common. It is due to lack of oil lubrication. My 91 Exploder 4.0 has 150K on it too. It lightly taps for about 10 minutes on a cold morning too. Just the sign of an aging engine. you might try playing around with different engine oil viscosities to quiet the tapping.
Or, you can swith over to the 5.0 H.O. like I am doing....ha..ha <IMG SRC="smilies/smile.gif" border="0">
'94 V8 Ford Explorer w/ 3in B. lift & 30.5/10.5
4X4, 4DR, Limited Edition
3.73 31 spline 8.8in Limited Slip axle
1992 5.0L V8 EFI w/AOD trans
http://home.earthlink.net/~asp84
asp84 is offline   Reply With Quote
