Need compressor bracket pics (OBA) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-12-2003, 09:25 AM   #1 (permalink)
Member # 16948
I need some pics of someones OBA compressor bracket on a late model fullsize with a 5.0...I dont want to pay bronco air $210 for theirs...that just seems a bit steep to me...measurements would be great also...i am going to fab something up in a bit either way, but what have you guys done???
Brian...
crackhead93 is offline   Reply With Quote
Old 06-12-2003, 10:13 AM   #2 (permalink)
FearMe's Avatar
Member # 1565
Go to any car lot and look under the hood of vehicles just like yours. Find one with air conditioning. That's what the bracket's look like. Take a picture. Develope the picture and head for the wrecking yard. Or better yet, go to the wrecking yard FIRST and find one with an engine like yours and pull off the parts you need.
I've outlived my dick.
FearMe is offline   Reply With Quote
Old 06-12-2003, 10:25 AM   #3 (permalink)
Member # 16948
i already have air...i need a pic of the bracket to mount an aux compressor in the eng comp for OBA...
Old 06-12-2003, 11:11 AM   #4 (permalink)
D60
D60's Avatar
Member # 6398
Wow, that's helpful. Yep, just go find a '93 5.0 mounted in a truck with a factory York. Brilliant.
http://soderblom.net/bronco/tech/york/
and here for a better shot of the bracket:
http://soderblom.net/bronco/tech/largealt/
Here's mine, same deal:
My factory a/c still blows cold
Dont' bother trying to use the stock Ford compressor anyway, it gets FAWKING hot when used for OBA purposes.
Sorry, I don't have better pics of the brackets. Some time spent with some scrap and a welder will get you there. Good luck.
"Take 300 people and on average 290 of them just generally suck at life"
D60 is offline   Reply With Quote
Old 06-12-2003, 09:34 PM   #5 (permalink)
Member # 9094
I got the broncoair bracket and love it. I also payed less than that since I got one of his first kits that had been used for test fitting. at the time he wasent sellign the pulley seperate and he was hte only one to make it so I got the kit otherwise I probaly would have bought the pulley them built a bracket. I can get you pics of the bracket if you like. I like the york sitting on this side better than the saborforce design on the other side of the engine. just seems to fit in the space better without having to relocate all the emissions junk
86 Toyota with stuff
Dust is offline   Reply With Quote
Old 06-13-2003, 07:18 AM   #6 (permalink)
D60
D60's Avatar
Member # 6398
The emissions junk went bye-bye and I can actually check the fluid level in my Sag pump Tensioning the belt is more straight-forward and the York is just more easily accessible and serviceable overall.
I really want Chris to do well but the Sabreforce design is superior IMO. I don't think Jim ever patented anything.....Chris should consider copying the Sabreforce design IMO..... but it won't work with newer motors with side-bolt alts.
Old 06-15-2003, 10:30 AM   #7 (permalink)
Member # 5821
Shoot just keep the stock 5.0 comp and run it. I had the york on my last 5.0 set up and this time I wanted to try the stock comp and it kicks but and puts out more that mine or my buddys york! And it is alot easier to install, ford took care of this for ya!
Buildem--Rollem--Tearem Apart--Get Rid of the Wife--And Start All Over!
BRONCO BUGGY; dana44,35spln 9", 37's, 351W efi, C5full manual w/comp brk, atlass 5:1, fox 16" air's master craft rubicon's, full hydro, and a girl friend that loves to help.
rokcrln is offline   Reply With Quote
Old 06-15-2003, 01:55 PM   #8 (permalink)
Member # 9094
I need all my emission crap unforgently, also I should add I did the saginaw pump with this kit also
