4:88 or 4:56? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-27-2001, 07:24 AM   #1 (permalink)
dblue351's Avatar
Member # 1001
Send a message via AIM to dblue351 Send a message via Yahoo to dblue351
Question 4:88 or 4:56?
I got a 91 bronco and i am getting new gears for it. I will be running 37 or 38 inch tires and was wandering what size gears to get. I want to still have some top speed like 75-80. So i was wandering if the 4:88 will be too much gear or if they will work out fine.
[URL="http://www.wt4x4.net"]WT4x4.com[/URL]
[URL="http://www.wt4x4.net/forum/showthread.php?t=352"]71 Bronco with stuff......[/URL]
[URL="http://www.youtube.com/user/wt4x4videos"]Videos![/URL]
dblue351 is offline   Reply With Quote
Old 11-27-2001, 08:46 AM   #2 (permalink)
1uglyranger's Avatar
Member # 6576
If your 91 has an overdrive, then go for the 4:88's. You can still do 80 without revvin' the motor out....
Brian--
Brian Whitford
711
Dysfunctional Rockcrawlers
Rage 4th............ "safety is our #2 concern"
1uglyranger is offline   Reply With Quote
Old 11-27-2001, 11:34 AM   #3 (permalink)
dblue351's Avatar
Member # 1001
Yes i do have overdrive, so i guess the 4:88 will be it, i was just afraid they might be toooooo low.
Old 11-27-2001, 01:53 PM   #4 (permalink)
CrazyHorse's Avatar
Member # 3420
Send a message via ICQ to CrazyHorse Send a message via AIM to CrazyHorse
with that size tire and an overdrive I'd be looking at a 5.38 as a minimum, possibly even deeper, as I have 5.38's going in my EB daily driver with 38.5 tsl/sx's and no overdrive
John Foottit
70 bronco, lightly modded
Contact me for your custom Cabinetry Needs
[URL="http://www.beniciacabinetry.com"][B]Benicia Cabinetry, Inc.[/B][/URL]
CrazyHorse is offline   Reply With Quote
Old 11-27-2001, 03:22 PM   #5 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
4:11's and no OD in my bronco with 38's
a they took away some power, but thier is still pleaty, i plan on jumping to 4:88's as well
Mark
welndmn is offline   Reply With Quote
Old 11-27-2001, 05:23 PM   #6 (permalink)
Member # 5821
I am running 4.88's in my 73EB and I have 35" tires and a NV4500 w/OD so at 80mph I am at 3,000RPM. I would go with 4.88 and not any higher due to a weaker pinion gear. Just my $0.02
Buildem--Rollem--Tearem Apart--Get Rid of the Wife--And Start All Over!
BRONCO BUGGY; dana44,35spln 9", 37's, 351W efi, C5full manual w/comp brk, atlass 5:1, fox 16" air's master craft rubicon's, full hydro, and a girl friend that loves to help.
rokcrln is offline   Reply With Quote
Old 11-27-2001, 05:40 PM   #7 (permalink)
Member # 6733
forget regearing... start praying that 8.8 doesn't split into 8 pieces when it sees your 38's.
Where's Rob? He's got those superior axles FS
Go 4.88
saf-t scissors is offline   Reply With Quote
Old 11-27-2001, 10:22 PM   #8 (permalink)
dblue351's Avatar
Member # 1001
Go 4.88
then i go 9 inch or bigger, build it bigger when it breaks thats my moto!
Old 11-29-2001, 12:23 AM   #9 (permalink)
Member # 6848
Go 5.13's... Good highway speeds (with OD) and good low gears at the same time.
71 1-ton EB
BITD 7200
IronBenderII is offline   Reply With Quote
