Member # 4073
I am kicking around the idea of converting my rear 10.25 to discs. Anyone know of a DIY swap for this axle? I know that TSM used to have the kit but it has since been discontinued. I do not want to use the late model 10.25 discs as they have a metric wheel bolt pattern- I want to keep mine 8x6.5".
Thanks <IMG SRC="smilies/smile.gif" border="0">
Dustin S. I had a brain-eating disease that died of starvation. |
i am planning this swap also. im going to use3/4 ton chevy front discs and calipers. will just make the brackets myself and i dont want an e brake. this may help but he used a tsm kit. just talkto the 14 bolt guys who are doing it, basically the same but the 10.25 is easier cause the drums just come off.
http://www.ford-trucks.com/articles/.../ford1025.html
the world might be passing you by, but its just going in circles 91 yj 5.7tbi/th350/d300/d60/14bolt/5.13s/detriots/xd9000i/soa on bds 3.5 yjs front/soa 4 inch waggys back/39.5 boggers on mrt beadlocks |
Member # 4073
Thanks for the response. Yeah, I've read that article a few times but too bad TSM stopped making that kit. I'll have to check out the 14-bolt stuff, see how that works.
#5 (permalink) | |
Member # 6398
I'm seriously confused, thought you had this all worked out and now sounds like you're back at square one.....
"Take 300 people and on average 290 of them just generally suck at life" |
yup your going way back, the dodge rotors and speedway brackets worked fine. go here this is what i did
http://www.pirate4x4.com/forum/showt...threadid=18416
the world might be passing you by, but its just going in circles 91 yj 5.7tbi/th350/d300/d60/14bolt/5.13s/detriots/xd9000i/soa on bds 3.5 yjs front/soa 4 inch waggys back/39.5 boggers on mrt beadlocks Last edited by yjtj; 10-29-2002 at 08:16 PM. |
What about a D61su/D70su from a E series van? They use the same wheel bearings, not sure about the spacing on them. Also the 4 bolts on the backing plates appear to be the same distance apart. Again just a thought, never tried it. You would also get the cool drum brake parking brake built right in.
EMS Offroad |
#9 (permalink) | |
Member # 6398
is what i did. this post was before i figured out the above url. the only 10.25 discs i have done so far were with the dodge rotors and speedway brackets and chevy calipers. i built it and it worked out fine, i did not put it in my truck cause i sold it, was offered to much money to say no, but i will be doing it again this summer maybe sooner and this one will actually go in my truck
#12 (permalink) |
Does anyone know about how mush this conversion will run, been thinking of doing it myself.
John
Win Win Properties, solving all of your maintenance, construction, and investment needs. When you WIN, we WIN. 707-588-9881 [URL=http://www.refugeforums.com]Refuge Forums - For Hunters Everywhere[/URL] |
