302 EB oil pans - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2003, 09:44 AM   #1 (permalink)
Member # 3480
Location: Chatsworth, Ca (LA) 482.3 miles to the Loon Lake enterance
302 EB oil pans
When swapping in a 93 Mustang 302 in to a Early Bronco, can you use the Mustang oil pan or should you switch to the 289 oil pan that was already on the Bronco?
My Bronchole, The hole all of my $ and time go in to.
Bronchole is offline   Reply With Quote
Old 08-12-2003, 11:30 AM   #2 (permalink)
Member # 595
Well I am not too familiar with them first hand but I do know that a friend of mine Chris used the stock dual sump pan off of a 93 T-bird on his conversion and I "think" that John did the same with his Mustang motor but you could ask @ the www.broncofix.com board because they both frequent it.
HTH
[COLOR="Red"]star[/COLOR]
EBSTEVE is offline   Reply With Quote
Old 08-13-2003, 05:36 PM   #3 (permalink)
Member # 5821
Yes they will work fine the only real draw back is they have two drain plugs and the front one is real hard to get to and makes a mess when pulled. But you can do it and the front sump holds very little fluid . My bud didn't even know it was their untill he was under my 91 stang and asked what the F is this other plug for? And I told him the same as the one in your EB, He was shocked he never saw it, and he is good about tune up stuff. So long story short it works but you can swap it for another pan and oil pick-up tube.
Buildem--Rollem--Tearem Apart--Get Rid of the Wife--And Start All Over!
BRONCO BUGGY; dana44,35spln 9", 37's, 351W efi, C5full manual w/comp brk, atlass 5:1, fox 16" air's master craft rubicon's, full hydro, and a girl friend that loves to help.
rokcrln is offline   Reply With Quote
