EB terraflx dana 20 question. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-31-2001, 01:44 PM   #1 (permalink)
Member # 659
Post EB terraflx dana 20 question.
I am looking into purchasing an EB that has this gear reduction although i don't know much about, etc. Any advice either good or bad is appreciated.
thanks,
Gator is offline   Reply With Quote
Old 08-08-2001, 07:09 PM   #2 (permalink)
howiebilt's Avatar
Member # 5244
Post
There is nothing shady about the terra low conversion . I wouldn't let that deter you from purchasing an EB with it already installed . <IMG SRC="smilies/jester.gif" border="0"> HOWIEBILT
howiebilt is offline   Reply With Quote
Old 08-10-2001, 09:58 PM   #3 (permalink)
Rubicrawler's Avatar
Member # 2037
Post
If you find one in good shape, buy it and enjoy <IMG SRC="smilies/smile.gif" border="0">
Mark Langford
KI6TMK
'86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's
Dysfunctional Rockcrawlers (TDO)
Rubicrawler is offline   Reply With Quote
Old 08-22-2001, 04:01 PM   #4 (permalink)
Member # 6653
Post
A Bronco without gear reduction is not good for rock crawling. You can do it, but you will be replacing clutches as fast as you can put them in. The TeraLow kit is not nearly as aggressive as JP Eater gears that can go in the D-20. TeraLow's are 3.15:1 and JP Eaters are 4.69:1. The stock Bronco D-20 has 2.46:1, so 3.15:1 is lower, but you will still want more reduction if you plan on rock crawling. See www.wildhorses4x4.com and look at the cold duck set up for a double.
Good Luck...Feathered Horse! <IMG SRC="smilies/glasses.gif" border="0">
Marlon
My drinking club has a 4-wheel drive problem...(Thanks Disco!)
marlon51 is offline   Reply With Quote
Old 08-23-2001, 11:21 PM   #5 (permalink)
AxlesUp's Avatar
Member # 1994
Post
how does the dana 20 hold up to 4.69.1 reduction? i would like to keep pandoras box closed if possible...
peace
Jw
AxlesUp@hotmail.com
AxlesUp is offline   Reply With Quote
Old 08-24-2001, 07:31 AM   #6 (permalink)
Member # 6139
Post
I wouldn't let that deter you from buying it. It should be better than stock anyway. If it did blow up, you could either pick up somebody's used t/c or rebuild yours with whatever you want, or of course go Atlas. <IMG SRC="smilies/biggrin.gif" border="0"> Buy it. Enjoy it.
73EB is offline   Reply With Quote
Old 08-24-2001, 04:02 PM   #7 (permalink)
Member # 6653
Post
The box does seem to hold up. The Rear output shaft is another story. After about 110:1 final ratio, the rear output shaft is under significant stress and appears to be the weak link. I am careful not to hammer the gas...something you should never do that low unless you want to break something, and I carry a spare rear output shaft. They are actually easy to swap on the trail. Only broke one shaft so far and I was...well...altered...if you know what I mean and my foot was doing the thinking. A couple companies are working on stronger shafts, but it appears the bearing would have to shrink so much that it might be a problem Peace! <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/eek.gif" border="0">
Marlon
