Member # 13561
89 302 efi ?
Ok I dont know if this should be in the newbie forum or not.
I did the unthinkable and swaped a 5.0 into my toyota, but dont hold that against a guy I searched for info but always come back to the PBB. 89 HO 302 EFi Question 1) does the EGR need to be hooked up. It runs without it but is the ECU going into limp mode ? is there a way to bypass the EGR ? 2) does the VSS need to be tied into the ECU to operate correctly ? 3) and last does anyone know what the mustang fuel pump flows ? LPH or GPH. Thanks, James |
Member # 595
I am curious what the motor is out of and is it a mass air, speed density and a HO? I am doing a HO mass swap rite now as well.
I have been told that the VSS is not required but I am not running yet so I don't know for sure. As for the pump I got this from the same guy as the stuff below The 83ish Ford Truck low pressure pump most folks use generates 72GPH @ 5.75PSI The 88ish Ford Truck high pressure pump most folks use generates 50GPH @ 90PSI The Stock 88-93 Mustang Fuel pump for compairson generates 23GPH @ 50PSI The most common aftermarket pump the Mustang crowd usually buys only generates 50GPM @ 50PSI 50 Gallons = 190 Liters This is an Email I got that explains how to do it. I recieved it from Ryan of the fordfuel injection site mentioned below. To remove the EGR system from your vehicle: Leave the EGR valve position sensor in the EGR and plugged to the harness: http://fordfuelinjection.com/images/egr01.jpg This confirms that the EGR is closed so the computer can calculate fuel and ignition with out warring about any Exhaust Gas Recirculation. You could remove the EGR and position sensor if you can add a resistor to send between 0.24-0.67volts to computer in place of the sensor to confirm there is no Exhaust Gas Recirculation. Unplug and remove the EGR solenoid: http://fordfuelinjection.com/images/egr03.jpg Cap any vacuum lines and ports left open to prevent leaks Unplug and remove the vacuum line to the EGR: http://fordfuelinjection.com/images/egr02.jpg Remove any vacuum lines left open to prevent leaks Ryan
[COLOR="Red"]star[/COLOR] |
Member # 13561
EB steve, the engine is an 89 5.0 from a mustang GT.
and its mass air. Thats great info. I can confirm that it opperates without these functions hooked up but...since I dont have an idiot light hooked up yet I cant confirm if the ECU is in limp mode or not. I can tell you I dont have any of the vacume solenoids hooked up to the EGR etc... |
Member # 15084
I have an '89 HO running in my Ranger right now. I left the EGR hooked up because of emmisions issues in the area. I used the stock fuel pump for the Ford Ranger ('88) and it works fine. I also run a low pressure pump as the stock Ranger system did.
I could never find a vacume wiring diagram but have mine hooked up right. I am running a VSS. I guess you can't. If it is a trail only rig I would not worry about it. If you have idle problems, not running the VSS could be the culprit. Also, not running it will slightly effect your gas mileage. Let me know if you need pictures or info. I am getting ready to build a new truck around the engine. |
Member # 595
3vze
Not to hijack your thread but your in the greater Seattle area, where about? SuperRanger If you could take a picture of the drivers side brackets I would appreciate it, I am trying to find a factory bracket that will allow me to put the A/C pump on. The T-bird setup I have puts the A/C pump way down and it hits the steering gear box. Anything would be great, I am hoping to have it wired by the weekend.
Member # 13561
SuperRanger, I have emmisions also but Im willing to bet that with a few tweeks it'll get passed, now that we dont have under hood inspection it should be alright ? I'll find out next april.
Since mines the EFI ver. I have the High press pump. but it was originaly a v6 anyway so .... might be fine. If thats true about the VSS then I need to learn more and find out how to convert the signal pulse from the toyota sender to send what the ford ecu is looking for. It is actually a daily driver...well sort of. I carpool so its more like a "When the wife feels like a change and, or I drive it on the weekend truck" |
Member # 15939
well i dont know about the other stuff, but you can trick a motor into thinking all is well whith a scan tool. Just get in and deleate the trouble code for the egr. If done right the motor will think its still hooked up (even if its not) and you should be good to go.
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... |
Member # 6733
There's no way that you can "trick" the motor into anything with a scan tool. Not where OBD-I Fords are concerned.
I would run a VSS. The motor does use it. If you're running a manual transmission, you'll have problems with it stalling on decel. I'd also run the EGR. I was talking about this same issue with D60 today. I have mine disabled at the moment, and the truck runs like crap. It doesn't know what to do at mid-throttle cruise with no EGR flow, so it jerks the timing around at random and sometimes causes knocking under load. Hope that helps.
Team Fat Shit and the Traveling Circus |
Member # 4176
Ive seen a few people that dont run the VSS and dont have any problems. I bet if you dont run it you wont either. Try it and see what happens, if your having problems with it running, trying hooking one up and see if it cures them.
#12 (permalink) |
Member # 7376
So the computer won't light the check engine light if the EGR solenoid is unplugged from the harness? I don't have the thermactor system any more so the EGR is the only thing that I'm keeping the coffee can around for... and it takes up valuable real estate! I also wouldn't mind getting rid of that dorky egr valve and tube, along with the extra vac lines associated with it and its solenoid
Won Ton 93 Bronco |
#13 (permalink) |
Member # 13561
The truck runs and drives right now but kinda petters out on power above 3.5k rpm. I am wondering is a VSS the same signal on any vech. ? if not I will need to figure out how to interface the toyota unit to work with the ford ECU(can anyone explain the signal pulses to me ?). The VSS on my toy runs the speedo.
BTW Im not running the thermactor or any of that junk. I also dont have any of the vacume lines hooked up so far except for the one to the Fuel Pressure Reg. |
