emissions removal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-02-2003, 03:25 PM   #1 (permalink)
Member # 17743
Location: columbus ohio on the weekends Toledo all week
Send a message via AIM to littlemule Send a message via Yahoo to littlemule
emissions removal
I have removed the air pump from my efi swap. There is 2 vaccum lines that were part of that, I think a pink and a black, do I just plug these or put them on vaccum from the manifold.
also the line that comes off the throttle body to the canister, con I just plg that or does it need to be run also.
Thanks everyone for the o2 sensor wiring problem help I did end up tracing from the pin and found it
This aint my first county fair!!!
broncohio.com
74 bronco 5.0, 36 tsl, Just sitting there begging for a little love!
littlemule is offline   Reply With Quote
Old 10-03-2003, 08:57 AM   #2 (permalink)
Member # 17743
someone has to know this!!!!!!!! so I just hook them together or to vaccum or what?????????????????????/
broncohio.com
Old 10-05-2003, 12:51 PM   #3 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
if I had to guess, I would say to trace the vacuum lines back to its source, remove and cap them off there.
masterbeavis is offline   Reply With Quote
Old 10-05-2003, 02:39 PM   #4 (permalink)
Member # 17743
they come off a small bank of what look like relays. when I removed the engine out of the f150 they were hooked to the air pump stuff. So what you are saying is I should just plug them and leave the relay wires hooked up
broncohio.com
Old 10-07-2003, 04:18 AM   #5 (permalink)
Member # 23110
Those are called the TAB and TAD soleniods.
Remove them and cap the vacuum lines. You can pull out the lines that went from the pump to the TAD / TAB
there should then be a vacuum suply hose that went to a vacuum canister, remove that line from the canister and plug that port
Ryan McCormick
[url=http://fordfuelinjection.com/]RJM Injection Tech[/url]
[url=http://fordfuelinjection.com/bronco]My Bronco[/url]
Parts replacement is [b]not[/b] auto repair, if you can’t [i]diagnose[/i], don’t open the hood!
Fireguy50 is offline   Reply With Quote
Old 10-07-2003, 12:55 PM   #6 (permalink)
Member # 17743
I do believe that the 4 are conected to the vaccum line from the canister. can I just leave them all conected to the canister or do I have to seperate the 2 and plug just them?
broncohio.com
Old 10-07-2003, 01:19 PM   #7 (permalink)
Member # 23110
Well I guess you can leave them, but I hate cluttered engine compartments. Just make sure you vacuum caps on all the nipples left open after you start pulling stuff off.
Side note: The other 2 seloniods you see there are fro the EGR valve. If you don't have a working EGR valve anymore you can pull all that stuff out.
Good luck, you might want to visit my site for some reading. It might make you feel more comfortable with the EFI install you have.
Ryan McCormick
