t case quesitons - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-03-2003, 05:54 AM   #1 (permalink)
krd
Member # 16472
Send a message via AIM to krd
t case quesitons
will a chevy 205 bolt to a c-6 or c-4 trans if i use a ford adapter on the 205?
i have and 82 bronce with a 302 an auto, which trans is it, a c-4 or c-6 or how can i tell from out side which one it is?
thanks for the help
“I couldn’t only do one thing-I don’t want the personal hell of oneness.” Itzhak Perlman
krd is offline   Reply With Quote
Old 10-03-2003, 07:07 AM   #2 (permalink)
FearMe's Avatar
Member # 1565
Probably a C6. Not sure about the t-case though.
I've outlived my dick.
FearMe is offline   Reply With Quote
Old 10-03-2003, 07:24 AM   #3 (permalink)
McDerry's Avatar
Member # 23250
advanced adapters might ahve some thing for you, Ill see if i cant locate a site with some pictures of the automatic drain pans on it, easiest way to tell wich is wich witha quick glance.
Bump stops, pfft.
McDerry is offline   Reply With Quote
Old 10-03-2003, 09:01 PM   #4 (permalink)
winch operator
bobbywalter's Avatar
Member # 15473
Send a message via AIM to bobbywalter
you may need a ford input shaft. and possibly a spacer...
if only
88 ranger ext cab pos hackjob powered by a 6.5 diesel clattering against a 4l80 thats punishing a f208 that is turning ford 60's rolling on 33-44 in tires depending on the mission at hand
how ya like me now??
bobbywalter is offline   Reply With Quote
Old 10-03-2003, 10:30 PM   #5 (permalink)
krd
Member # 16472
well its a c-6 i checked trans kit at shucks to see pan shapes from the gaskets....
so all i need to know is will the 205 chevy got to a c-6?
or any idea where i can compare the 205 gaskets or spline counts?
if the 205 to adapter is symetrical then it bolts to that adapter the same no matter what side drop.. and then if the splines are same count then it should work with the ford adapter???
Old 10-03-2003, 10:33 PM   #6 (permalink)
Member # 14600
It's most likely a C6 and an NP208. Or, didn't they also put the AOD behind the 302s Alpo would probably know.
Just a redneck trapped in a brown man's body
Oatmeal is offline   Reply With Quote
Old 10-04-2003, 08:40 AM   #7 (permalink)
Member # 324
Are you using a different front axle as the output is on the wrong side.
Family, Friends, riders and racers, its who we are.
smurfsdad is offline   Reply With Quote
Old 10-04-2003, 01:37 PM   #8 (permalink)
krd
Member # 16472
i am putting a 302 in a 1990 4 runner... so trying to figure out the the cheapest or best way to do do it.. it needs a passenger side drop i want to use and auto trans... but i think the best way now i just get an adapter to use stock toy trans and keep the manual....
info i have found is that the chevy th 350 205 t case needs a ford spline input shaft for sure and not sure if the adapters will still bolt straight up.. i looks like it from the pics i have seen...
thoughts now are by the time i buy trans and rebuild the 205 and have drive lines made its going to be more expensive then jsut adapting the 302 to the toy tranny and i will increase weight and lose some low range in the process and have alot more custom work to boot...
