Dana 70 help??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-13-2003, 02:28 PM   #1 (permalink)
Member # 15049
Dana 70 help???
The axle is from an 85' F350, this is all I know for sure. I searched the Dana site and ran the BOM. The site does not tell me much, or atleast I don't know what to look for. The BOM is 605247-4, on the webbing it says, 70 1SU. Is this just a dana 70U and what does that mean?
Does it accept the regular d70 gears and locker choices?? How low is the gearing options? Thanks for the help, my ass is numb from searching for three hours.
Also, on the actual tag, the BOM says 605247-4 LS . I'm guessing it's for the limited slip?? I really need to know if I can still get a detroit and some 5.13 - 7. ???? on the gears.
1986 K30
sw99 is offline   Reply With Quote
Old 10-15-2003, 09:39 PM   #2 (permalink)
Proeliator's Avatar
Member # 12042
Send a message via Yahoo to Proeliator
And I thought they were just putting in Sterlings then...
The LS is for limited slip, like you figured. No reason why you can't just stuff in that detroit and 5.13s. Same thing I run in my 70.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE]
'73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s.
Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url]
Proeliator is offline   Reply With Quote
Old 10-17-2003, 04:51 AM   #3 (permalink)
speedo's Avatar
Member # 23262
70U
If it is a 70U, which it sounds like it is, then everything is the
same as a 70B except for the inner pinion bearing set. The cup is
the same as a 60 but the bearing has the same id as a regular
70, 70B, 70HD. So if your not going to replace pinion bearings
just consider it the same as a 70B. And if you need some inner
pinion bearings for a 70U let me know I've got some left over
after buying some gearsets for 70U to use in a 70B.
Gus
speedo is offline   Reply With Quote
Old 10-18-2003, 08:04 AM   #4 (permalink)
Member # 17947
Send a message via AIM to jaluhn
Mid 85 is the changeover. I suspect a build date around 1/85 is when it changed. Early 85's run the d70. I also suspect they went to the later design 6.9 block at the same time.
-John
jaluhn is offline   Reply With Quote
Old 10-18-2003, 06:11 PM   #5 (permalink)
Member # 15049
Thanks for the info guys! Looks like this should be a pretty damn stout axle for a 4500 lb. buggy.
1986 K30
Old 10-19-2003, 10:03 AM   #6 (permalink)
Member # 4243
My buddy's 85 F250 (supercab diesel) came with a Dana 70 as well. He swapped in gears from an 80's Chevy cube van (G-series, DRW, cutaway). How's that for interchange?
90-93 CTD jalopies
u2slow is offline   Reply With Quote
Old 10-20-2003, 05:31 PM   #7 (permalink)
Member # 8646
I just swapped in this 85 D70 from a diesel utility body SRW it's very stout
http://www.superford.org/registry/ve...a.php?id=86579
04 Jeep Rubicon Tons of upgrades on 35"MTRs
02 F350 Powerstroke
wildbroncobilly is offline   Reply With Quote
Old 10-21-2003, 08:38 AM   #8 (permalink)
Member # 15049
Nice pics Bill! That is a sweet looking F150 you got there. Nice to get rid of that TTB crap, huh? Yall got some serious rust out der.
1986 K30
Old 10-22-2003, 05:06 PM   #9 (permalink)
Member # 8646
Yeah solid axle was the only way to go! We get lots of snow up here
http://www.superford.org/registry/ve...a.php?id=80916
02 F350 Powerstroke
Old 10-22-2003, 11:08 PM   #10 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The 10.25 was not used in all diesel applications from 85 on, I had an 85 diesel 250 parts truck with a 10.25, but, my 86 F350 Crew Cab 4x4 SRW has a D60 front/70 Rear. From what I have seen, the early post 10.25 high GVWR diesel applications still used dana axles.
Evan
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is offline   Reply With Quote
