79 bronco q? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-11-2001, 11:09 PM   #1 (permalink)
Member # 4682
Lightbulb 79 bronco q?
what is the stock gearing for a 79 fulsize bronco. And can you get the axle in a high pinion? Thanks
<IMG SRC="smilies/biggrin.gif" border="0">
Um...what?
finder_87 is offline   Reply With Quote
Old 08-12-2001, 04:17 AM   #2 (permalink)
Member # 4243
Post
Front axle IS high-pinion. Available ratios were: 3.00, 3.50, & 4.09.
90-93 CTD jalopies
u2slow is offline   Reply With Quote
Old 08-12-2001, 04:24 PM   #3 (permalink)
Member # 3373
Send a message via ICQ to yjtj
Post
the rear is a low pinion 9 inch and if ya wanted to spend the money currie could sell ya a high pinion 3rd member for that
the world might be passing you by, but its just going in circles
91 yj 5.7tbi/th350/d300/d60/14bolt/5.13s/detriots/xd9000i/soa on bds 3.5 yjs front/soa 4 inch waggys back/39.5 boggers on mrt beadlocks
yjtj is offline   Reply With Quote
Old 08-13-2001, 07:32 PM   #4 (permalink)
Member # 4068
Send a message via ICQ to TX4WHEELER
Wink
Dont the high pinion Currie 9" rears actually use a 8.8" ring and pinion?
Robert Hutson (TX4Wheeler)
1978 Ford Bronco
460, C-6, D60 Front with ARB and 35 spline outers, D70 rear, disk brakes, welded diff,7" lift, 38.5X14.50 TSL/SX's, Warn 8274 winch, Hydro Assist steering
TX4WHEELER is offline   Reply With Quote
Old 08-14-2001, 09:40 AM   #5 (permalink)
macgyvr's Avatar
Member # 936
Send a message via ICQ to macgyvr Send a message via AIM to macgyvr
Post
My 79 has reverse cut D44 front axle and swapped in D60. I broke the 9inch.
The front axle has 3.50, the rear 60 has 3.54. Its all stock right now. Running 31s with a 351M.
mac 'old iron rulz' gyvr
302 Rosco Racin - 26th KOH 2013/2011 Finisher/Qualified for KOH 2014
Follow Rosco Racin on facebook!
Thanks to our Sponsors!!!
BFGoodrich/Great Lake Off Road
NAXJA president
Co-DAWG for TREC #747 "The Anger" Ranger
macgyvr is offline   Reply With Quote
Old 08-14-2001, 12:16 PM   #6 (permalink)
Member # 6350
Post
Yes the High pinion rear 9" uses a 8.8 R&P set for the conversion
[url="http://www.bronco78.com"]bronco78.com[/url]
[url="http://www.superford.org/registry/?vID=144"]Bronco Specs[/url]
[url="http://www.teamalaska4x4.com"] Team Alaska[/url]
[url="http://www.outbackchallenge.com"]Australian Outback Challenge
[/url]
bronco78 is offline   Reply With Quote
