460 stroker? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-23-2003, 06:08 PM   #1 (permalink)
broncoformudv's Avatar
Member # 24310
Send a message via Yahoo to broncoformudv
460 stroker?
What is the most affordable method of stroking a 460? I would like to get 514-521 cubic inches out of it.
broncoformudv is offline   Reply With Quote Quick reply to this message
Old 11-24-2003, 03:47 AM   #2 (permalink)
Member # 16383
Buy a stroker kit from PAW and do all the work yourself would be the cheapest.
Good leaders are scarce, so I am following myself.
rabidranger is offline   Reply With Quote Quick reply to this message
Old 11-26-2003, 12:50 PM   #3 (permalink)
Member # 10165
Don't know about the most affordable method but if you go 514 or 521 you will have one helluva overbore (.120) IIRC and you will need to have the block sonic tested for casting flaws before doing this. Just go 495 (.060 and BBC rods) and you will have a very nice BB Ford on your hands.
Try www.speedomotive.com and look at there stroker kits and engines. I bought a 495 from them and was quite pleased with it's performance. They can build the 521 if you want.
Hey Norm (Pln BaLL) You wanna chime in here?
Steve
TEAM BREAKALL "Wheel with authority!"
Ultim8kaos is offline   Reply With Quote Quick reply to this message
Old 11-26-2003, 08:00 PM   #4 (permalink)
Member # 7780
Send a message via ICQ to axaviere Send a message via AIM to axaviere
hey steve, look what you started.
i got a 460 in there too. where do you find the info on stuff like which BBC rods to use and would there be a special piston needed? i want to start building a 460 or bigger soon. i have an 87 block now and i have some d0ve heads. what can i wring out of it and manage to keep the CR low enough for cheap pump gas?
steve, what are you doing in that pick on your avatar? you got a superford site or pics of your rig?
i have seen kits for strokers & stuff in catalogs from summit, PAW, & other auto places plus on ebay. your local motor shop should be able to get a kit too pretty cheap i would think. i dont think there is a way build a stroker re-using parts in your motor is there? i have heard all different combos. 302 pistons & chevy rods was one i recall.
they call it
79 custom 4" lift, 460 4.10 D44 8lug/D60 the front D60 is in my yard & almost ready!! 36s are on, f350 brake upgrade, i just got my rear disc kit now ... 10.25 in the future possibly
axaviere is offline   Reply With Quote Quick reply to this message
Old 11-26-2003, 08:20 PM   #5 (permalink)
Member # 12927
Send a message via AIM to fordman7795
in a 351 stroker kit you use 302 pistons. was that what you were thinking?
1993 Bronco
fordman7795 is offline   Reply With Quote Quick reply to this message
Old 11-26-2003, 11:38 PM   #6 (permalink)
Member # 7780
not really sure. 460 is great, but we always seem to want more. i thought it was 302 pistons, but it could be 302 rods. i want the how 2 build big blocks book and talk to the guys at the motor shops to see what i can do. strokers sound nice... but they arent cheap.
they call it
Old 11-27-2003, 07:57 AM   #7 (permalink)
Member # 10165
Lookin pretty good Ant! So I am responsible for that rig, am I?
My avatar is the last obstacle on Upper Helldorado in Moab. Took a bunch of body damage on that trail!
I just had Speed-o-motive build my stroker motor. I am not sure which BBC rods they used but it was supposed to give me a longer stroke than any of the Ford rods. They call it a long arm motor, (piston spend more time at TDC), supposed to create more torque. Pistons will depend on the rod length as to where the wrist pin hole is located blah, blah, blah. Check out the link in my previous post. They have stroker kits, complete engines etc. for just about any engine you could want.
IIRC you can check out Ford Motorsport catalogs for some big C.I. engines as well.
Steve
Old 11-27-2003, 11:56 AM   #8 (permalink)
Member # 7780
its all your fault
yup, its your old 4" kit & now i got a D60 im prepping to go in. you want to hear the funny part? i havent beed able to wheel since i put in the rear 60 cause the ratios dont match. i got a detroit for the rear for cheap too. 460 & im looking at a doubler. what did you put on the bronco frame?
they call it
Old 11-27-2003, 02:57 PM   #9 (permalink)
Member # 10165
Ditched the Bronco body for a 1936 (gulp, should I say it) Chevy cab! Hybrid in every sense of the word. It is still a little ways off from completion but I plan on havin it ready for Chile Challenge in Las Cruces, NM in Feb. I also picked up a kickass little Yota and have been wheelin that too.
Get that 60 in and go for the doubler and don't look back. You won't regret it.
Steve
Old 11-27-2003, 07:54 PM   #10 (permalink)
Member # 7780
man thats funny, i see these Yota's in all the mags and everytime i see one cheap in the paper i want to snag it & mess with putting the D44 8 lug & a D60 rear under one. plus theres the better mileage factor. i know Yota's hold up well as is it seems, but i got these axles lying around & i want to build something. possibly get them under a bronco II or something smallish like that. get the 60 in, get the rear disc brakes on, get some rims. i was looking at a set of 20" double beadlocks & running XL's. tires are pretty cheap i hear. i need a winch too.
they call it
Old 11-27-2003, 10:01 PM   #11 (permalink)
Member # 4176
What motor are you using? Ive wanting to try the 351W long rod for a long time when i rebuild my Mustangs motor. You have any problems with it? I hear having the wrist pin up into the Oil control ring isnt a good idea. Which has to happen since the rods so long. Any comments?
StoopidMonkey is offline   Reply With Quote Quick reply to this message
Old 11-28-2003, 05:17 AM   #12 (permalink)
Member # 10165
Monkey,
I started with the 460 and went to 495 with it (probably what they are calling the 501 now). Speedomotive did the long block for me. Had absolutely no problems with it. One of the smoothest running engines I've had. You might want to check out their website for their offerings in the small block.
Steve
Old 11-30-2003, 08:36 AM   #13 (permalink)
Member # 6130
Buy or have a machine shop offset grind your crank to 4.300 and grind the rods journals to BBC specs. Use 6.800" long BBC rods, and many piston companys have a part number for this (for example Arias 1340600). And don't go overboard with the overbore. You don't get any power from boring out your block.
JYS
86 Ford Bronco W '78 460/C6/NP205
On board air and Rockwells
Junkyard Slug is offline   Reply With Quote Quick reply to this message
Old 11-30-2003, 09:18 AM   #14 (permalink)
mj
Member # 1919
if you are gonna stroke it you may as well go all the way to a 4.5 inch crank.
Flatlander has kits fairly cheap.
385 series Fords are designed to be HUGE displacement engines.
557 is not uncommon, relatively cheap in the stock block 0.080 overbore
385 engine forum
http://www.network54.com/Hide/Forum/85220
mj is offline   Reply With Quote Quick reply to this message
