Interesting discovery - Ranger/Explorer 8.8" - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-13-2003, 04:17 PM   #1 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
Lightbulb Interesting discovery - Ranger/Explorer 8.8"
Last weekend I helped a friend swap my old '92 Explorer 8.8" rearend into his '93 Ranger. Strangely enough the Explorer axle turns out to be one inch wider than the Ranger axle. I had always assumed they were the same width.
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote
Old 12-13-2003, 04:32 PM   #2 (permalink)
Member # 10063
Yep
'83-'92 Ranger rears = 56.5" wide
'93-current Ranger rears = 58.5" wide,
'90-'01 Explorer rears = 59.5" wide.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 12-15-2003, 06:58 AM   #3 (permalink)
Member # 18283
yep they came from the factory with a different offset wheel to compensate for the axle difference by about 3/4 inch if I remember right... just got done doing the same thing to mine.
As has already been pointed out the disc brake versions from the explorer are even wider.
for further info look@ www.therangerstation.com
There are no rules. You have to think!
demonranger is offline   Reply With Quote
Old 12-15-2003, 03:18 PM   #4 (permalink)
Member # 11804
B-II axles are wider than Ranger axles too. At least the '86 7.5 was wider than the '85 Ranger 7.5 we tried to put the shaft in.
Radoje Spasojevic
"Nerves of Chicken, Brains of Chipmunk"
--300M sucks, I use Super Impacto!!!
"Your service was more than prompt. Your product is more than welcome since I both vomit unpredictably and am incontinent - thank you SO much. C.E. 4/8/03 "
OffRoadPoser is offline   Reply With Quote
Old 12-15-2003, 03:32 PM   #5 (permalink)
Poseur SUV
Member # 610
I'm not sure about that one. When I swapped a disc brake axle into my Explorer there wasn't any difference in width.
Also your idea about the wheel offset isn't right either.
Paul Gagnon
"No Brain, No Pain"
Old 12-24-2003, 02:38 AM   #6 (permalink)
Member # 2285
Paul, when swapping the explorer 8.8 into a ranger, you obviously have to weld on new spring perches...but is there any other modifications that have to be made? Does the E-Brake connect up okay? thanks.
Prerunner is offline   Reply With Quote
Old 12-27-2003, 07:27 PM   #7 (permalink)
Member # 6237
Send a message via AIM to wilber
b2 and ranger axles are different, one has a centered diff, the b2 i think, and the ranger has a offset diff to compensate for the gas tank, thats why you wouldnt be able to swap shafts
wilber is offline   Reply With Quote
Old 12-28-2003, 06:47 PM   #8 (permalink)
Poseur SUV
Member # 610
You will need to weld on spring perches and shock mounts. The brake hard lines are bent a little different but you can swap the Ranger ones onto the Exporer axle easily. There are a couple of different styles of drum parking brake cables for Rangers. They are easy to change so if the one that is on the Explorer axle doesn't work just put your old Ranger cables on. Disc brake axles require changing the hard lines and cables(from the first cab mount back). They are not interchangable with the drum brake parts.
Paul Gagnon
"No Brain, No Pain"
Old 12-30-2003, 12:19 PM   #9 (permalink)
Member # 18283
I stand corrected the disc brake version of the explorer 8.8 is the same width as the drum brake version.
