Tie rod for HP Dana 60 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-22-2003, 12:17 PM   #1 (permalink)
Member # 9630
I am looking for a new tie rod that I can remove and change both ends. I found a couple places online but they are saying because their tie rods a bigger around they hit the diff cover on the Fords, I guess its not such a big problem on the Chevys. Does anyone know of a good tie rod that has both ends removable that will clear the diff cover?
'96 GMC Z-71 - HP Dana 60 and 14FF with 5.13's and Detroits. Sitting on 39.5 TSL's
Masher is offline   Reply With Quote Quick reply to this message
Old 12-22-2003, 12:24 PM   #2 (permalink)
Member # 6733
I put two washers under the steering stop on one side. That fixed the diff cover clearance problem.
Team Fat Shit and the Traveling Circus
saf-t scissors is offline   Reply With Quote Quick reply to this message
Old 12-22-2003, 08:01 PM   #3 (permalink)
Member # 16945
i built a tie rod from 1.25" dia tubing and used the chev ends. i have it mounted on top of the steering arms (not high steer) and it doesn't hit the cover- even with a .25" thick rock ring welded to the cover.
1990 bronco, d60, 14bolt, 5.13's and detroits, 325 85r16 XML's and 39.5 swampers on hummer rims
1968 bronco, spool, 4.10, 32"bfg's
built4wheelin is offline   Reply With Quote Quick reply to this message
Old 12-31-2003, 12:35 AM   #4 (permalink)
Member # 7780
Send a message via ICQ to axaviere Send a message via AIM to axaviere
if you get one built, have them bend it to match the D60 stock tie rod.
they call it
79 custom 4" lift, 460 4.10 D44 8lug/D60 the front D60 is in my yard & almost ready!! 36s are on, f350 brake upgrade, i just got my rear disc kit now ... 10.25 in the future possibly
axaviere is offline   Reply With Quote Quick reply to this message
Old 01-01-2004, 05:56 PM   #5 (permalink)
Member # 10345
Send a message via AIM to Deadman514
I have the Performance Unlimited 1.5" RockProof tie rod on my 60 front and I have no clearance issues. It is close -but it doesn't touch.
78 Bronco, 4"suspension-3"body lift
42" Swampers on Eaton 8 lugs, Performance Unlimited Rockproof steering/trac bar, Westtexasoffroad Steering box -modified Saganaw pump and Redneck Ram.
514 stroker, Edelbrock 750 carb, Jacobs ignition & wires, Fluidampr, Pete Jackson gear drive
6" K&N w/x-tream top,L&L underdrive pulleys,
L&L headers,Dual Flowmasters, B+M C-6, TCI Truckmaster TC, All Aeroquip
braided stainless hoses, Dual Optimas, Powermaster 140amp alt.
High Angle 1 Ton CV Driveshafts front and rear -now with 1410 joint in the rear and driveline e-brake,
F-350 Booster/master, Braided stainless brake lines,14 bolt 4.56 welded rear with TSM disc brake conversion -Dana 60 front Herculined interior
Deadman514 is offline   Reply With Quote Quick reply to this message
