Rapey
Although mine's an F-150, the axles are similar except for the whole leaf-coil difference. I managed to break the stock bracket for the driver's side axle beam in two places. After replacing that bracket with a 6" lift bracket, the frame around that bracket's mounting points cracked, which I eventually fixed.
I've got 35" tires on it now, and haven't had any problems as far as shafts or u-joints go, but of course, I don't exactly thrash it off road.
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum: http://www.pirate4x4.com/forum/outdo...-may-31-a.html |
Member # 10063
The TTB axle itself is quite strong. The shafts/joints are the same size as other Dana stuff.
Problems with TTB usually stem from cheapo liftkits (unfortunately, thats a majority of them). The Skyjacker Class II stuff is one of only a couple standouts. The leafsprings aren't going to let it flex much, though. Your F250 probably has a D50 axle. This axle has somewhat larger joints than a D44, but not as big as D60 parts. Ring dia. is 9", with 30 spline shafts. Check the bottom of the pig for a big 44 or [b]50]/b] on it. I would agree with the 35" tire recommendation if its locked. A 50 with open diff or L/S, it could live ok with 37s or so.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] |
Member # 14279
Yeah, I would say 35's too, not more than 37's though.
Chris 1992 Explorer - D44 Solid axle - 9" Rear - James Duff extended radius arms - 35/12.50 BFG MTs - Front/rear ARBs - RS9000X - 4.56 [url=http://www.4x4ord.com]Club 4X4ORD[/url] [u]Because Life's Not Made of Pavement[/u] |
Member # 17313
check your hubs to tell what front axle you have, or the GVWR tag. The dana 50 uses the same hubs as a 60, it is obvious which front axle you have.
I've been beating my f-150 for years, with a mildly built 351, grany 4 speed, and 35's nothing has ever broken. A 50 should handle 37's just fine open, locked it may get sketcky,
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
#8 (permalink) | |
Member # 9098
I can get the truck cheap. I was thinking about building a hybrid out of it....take the body off and put a ranger cab and hood back on it....weld up a cage, bolt on 44's (no lift) and give it hell. Should I pass on this one and wait for a one ton? |
Fawkin Fordhead
Also, any F250 with the Sno-Fighter package got a D50, even the LD's.
But, the only F250 that's guranteed to have a D50 is an extended cab with a 460 or diesel. For 85 and 86, EX. cab F250's only came as HD's, later, I'd assume was the same. Also, the 5 speed behind that 351 is a ZF, if the truck is fairly cheap, I'd grab it, and find a D60 to swap in later, unless you can find a better deal on a F350.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build Last edited by 82F100SWB; 12-30-2003 at 05:28 PM. |
#12 (permalink) |
Member # 9098
Its on Ebay right now for $665. I think I'm gonna pass on it.
Too many other things going on right now. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2450731510 |
