Member # 6429
i want to know how to convert a ford 9" rear end to a front end, i have 2 and i want to make one my front axcel, any info will help
thank you
"All four wheels must participate" |
Member # 303
It's easy, if replacing bolth tubes and adding D60 ends is some thing your into. Currie is the only one I've ever heard of using 9" for front ends. Then only with the high pinon set-up. You would be miles ahead to just buy or find a D44 or D60. <IMG SRC="smilies/jester.gif" border="0">
Still can't get used to making a right to go to the beach |
Member # 205
check under my user profile for my web page,
I did a complet write up on the building of a hybrid 9"/D60F axle. You can click on the link and it will connect you to the article. B
It's not the finished product, It's building it, thats important B Built |
Member # 14600
Look under the axle build up section, it'll give you an idea about whats involved.........Hans http://sunrayengineering.com/main.html
Just a redneck trapped in a brown man's body |
Axes of E-ville
Member # 48097
I would be careful about running a differential originally designed as a rear axle in the front. While many have made doing this sound easy and foolproof, a rear axle is designed as a REAR axle.
When a rear axle differential is placed up front, all the power from the engine/trans/t-case is now transferred to the weakest side of the ring gear i.e. the coast side. Doing this wears out the ring and pinion relatively quick. They do not recieve the proper lubrication as they were not designed for this application. This is why most MAJOR axle manufacturers use "reverse cut" or "reverse rotation" ring and pinions in their front axles. There are exceptions. Currie Enterprises and HI-9 make high pinion differentials designed for front, reverse rotation applications. And there are gears for these center sections. However, these are not inexpensive alternatives. Like Pepdaddy said, a much more viable choice would be to find a D44 or D60. But, if you are set on a 9" up front go for it...just post your pics. |
#7 (permalink) | |
Member # 14600
.........Hans
#8 (permalink) | |
Axes of E-ville
Member # 48097
My point was this, if someone is going to take the time to build a custom front end, why take the risk of installing a low pinion diff. that runs on the coast side of the ring gear? Pressing new tubes, knuckles, etc. into rear axles to convert them to front axle duty is nothing new. I understand the advantages of running a 9" as a front axle...overall strength, drop-out diff, etc. But what about cruising in 4HI, high-speed runs through/over obstacles, etc. for any length of time? People build whatever suits THEIR needs. Thereby, build whatever YOU want. |
#11 (permalink) | |
Member # 14600
............Hans
#12 (permalink) | |
Axes of E-ville
Member # 48097
For the full time 4x4's, part time conversion kits solved that problem. |
#13 (permalink) |
Sunray is the only manufacturer that I'd trust with a 9" front axle. Good folks. I have one of their rear axles, and a 609 is on the wish list.
I'm not sure that they've had many (if any) failures. Call em up and talk about it.
I consider myself a student of the game, it's just too bad I'm in special ed... |
#14 (permalink) | |
Member # 14600
Just a redneck trapped in a brown man's body Last edited by Oatmeal; 06-27-2005 at 05:50 PM. |
#15 (permalink) | |
Axes of E-ville
Member # 48097
#16 (permalink) | |
Member # 14600
Hey, I don't really care for full time rigs, it's just that I'm an argumentative person by nature and enjoy a good fight...er..debate And no offense taken about the Currie Enterprises comment .........Hans
Just a redneck trapped in a brown man's body Last edited by Oatmeal; 06-27-2005 at 09:35 PM. |
#17 (permalink) |
Pigs Fly
I know a guy who blew up a Currie 9" front, on 38.5 SX's.
For what that's worth, which is next to nothing. He did it grabbing gears in a part-time 4-hi drag launch while racing a Civic. Those 5.13's put up a fight. Until the ring gear exploded.
'94 XJ RIP, time to move on New East Coast TTB racer in the works, trimmin' the fat... Flying Pig Racing #512 |
#19 (permalink) |
Member # 27392
The currie 9" uses 8.8 gears and thus is weaker! True Hi9 is the shiz that gets! I've researched this and came up with many manufacturers and believe the 69 will become more and more popular. The 9" is a very strong diff. and lighter than a 60 add the 60 outers with 35 spline and you got something very good and very expensive. Details of what I came up with and others here: http://www.fullsizebronco.com/forum/...ght=ford+front
Swat. |
