ford 6 cyl diesel conversion? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-29-2004, 04:46 AM   #1 (permalink)
Member # 12101
Sorry if this is a repost, I searched....nothing came up.
I heard about a Japanese kit to turn a ford straight 6 into a diesel. Too bad I can't find ANY info about it. (I like diesels)
Anybody heard anything, or got some info?
Thanks in advance!
dieseltoy is offline   Reply With Quote
Old 03-01-2004, 04:44 AM   #2 (permalink)
Member # 16383
I am just pulling this outta my ass, but... I wouldn't think that the heads and block could take the 15:1 or higher compression ratio required to make it a diesel. You would also have to spend big bucks on a high pressure diesel injector pump and system. But I am just ASSuming all this...
Good leaders are scarce, so I am following myself.
rabidranger is offline   Reply With Quote
Old 03-01-2004, 05:38 AM   #3 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
Yup...
Just another urban legend it is... The 300 is heavy built, but not THAT heavy duty.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is offline   Reply With Quote
Old 03-01-2004, 10:28 PM   #4 (permalink)
Member # 324
I have seen a 6 cylinder diesel in a Lincoln at the wrecking yard, i was gonna yard it but didnt get the chance. It was a factory setup and it was a slant design. I'm gonna get the next one i see.
Family, Friends, riders and racers, its who we are.
smurfsdad is offline   Reply With Quote
Old 03-02-2004, 03:19 PM   #5 (permalink)
infoford's Avatar
Member # 14168
Send a message via ICQ to infoford Send a message via AIM to infoford Send a message via MSN to infoford Send a message via Yahoo to infoford
are you sure it was a lincoln Dodge had the slant 6 deisel and gas
Trent NORTH COUNTRY SPECIALTIES www.ncspecialties.com
home of the picador & Dually 1979 Ford CC 4X4
infoford is offline   Reply With Quote
Old 03-02-2004, 04:17 PM   #6 (permalink)
Member # 324
Most definetly a lincoln, it was the size of a versailles ? and even could have been one.
Old 03-02-2004, 04:30 PM   #7 (permalink)
Member # 24605
Found this here http://www.geocities.com/motorcity/s...3545/mark.html a 2.4L turbo diesel in a Mark VII
All 1984 Marks came standard with the 140hp 5.0 with the AOD transmission, but there was a Turbo Diesel I-6 option that was poorly received. The I-6 was mated to a quick-witted 4-spd automatic made by our German friends at ZF. The rear axle had a 3.73:1 gear (standard was 3.08:1) to aid in the the diesel's acceleration. There was a 5-speed manual designed for the car, but I have yet to see one in a production Mark. Rest assured, a 5-speed turbo Mark would be the RAREST of the breed.
Though the motor was made by Steyr, a subsidiary of BMW, it was a diesel and its 115hp was not nearly enough for a Mark VII. At least it was dead reliable. These cars had a dual exhaust setup, but one pipe was for the turbo's wastegate. Diesel cars had a "diesel" badge on the decklid, more hood insulation, and a large rubber strip that isolates the firewall and strut towers from the engine bay. Apparantly these goodies made the crude Fox car feel more like a German car...albeit an oil burning German car. Amazingly, the heavy duty radiator of the Turbo Mark VIIs found its way into the 1993 Mustang Cobra R.
wuzabronco is offline   Reply With Quote
Old 03-02-2004, 11:22 PM   #8 (permalink)
infoford's Avatar
Member # 14168
ok I will shut up now
Old 03-03-2004, 03:35 AM   #9 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Um, dude, no such thing as a slant six diesel... In the late 70's ma Mopar did put a Mitsubishi diesel in trucks tho...
Old 03-03-2004, 05:00 AM   #10 (permalink)
Member # 324
How can you say that with the pic staring ya right in the face ?
Old 03-03-2004, 05:13 AM   #11 (permalink)
Dave C's Avatar
Member # 21297
Send a message via MSN to Dave C Send a message via Yahoo to Dave C
it's an optical illusion, the pictures taken at an angle
1978 Bronco buggy. Propane powered 351m, c-6, 4.56 gears.
Dave C is offline   Reply With Quote
Old 03-03-2004, 05:35 PM   #12 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
I was responding to this:
There was an OHC /4 diesel version of it , but, that didn't work to well, and got converted to gas, hello K-car engine.
Old 03-03-2004, 07:00 PM   #13 (permalink)
infoford's Avatar
Member # 14168
my neighbor had a 1976 dodge 2wd 1/2 ton truck it had a slant 6
and it was a deisel engine it was the most gutless thing I ever seen but it was a deisel and it was a slant 6
