Ford Nine Inch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-16-2004, 08:34 PM   #1 (permalink)
Member # 15658
Ford Nine Inch
I tryed searching but the search function but the stupid thing doesn't want to work for me. All I want to know is if I can put 35 spline axle shafts into an 1972 Early Bronco 9"? Or am I stuck with 31 splines as an option?
OH CANADA is offline   Reply With Quote
Old 03-16-2004, 09:36 PM   #2 (permalink)
Member # 16225
You are stuck with 31 splines as max. You would need big bearing ends as well as a different case to go to 35 spline.
toyota crawler
1tonYJ project
dittohead is offline   Reply With Quote
Old 03-16-2004, 10:25 PM   #3 (permalink)
Member # 10398
Phase3 of my buildup in two years planned to have a full width 40 spline 9". Front will be a 60. Figure i should be all good for 42s on my EB.
But like he says, different case.
Hellraiser is offline   Reply With Quote
Old 03-16-2004, 11:18 PM   #4 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Depends on weather or not he has a small or large bearing housing now, but you're right, more than likely its a small. But no matter what you will need a new carrier.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is online now   Reply With Quote
Old 03-16-2004, 11:53 PM   #5 (permalink)
Member # 16225
I have a factory case in my EB right now with 3.250 carrier bearings, just like an aftermarket carrier. Does this mean i can go to 35 spline? Its out of an old lincoln car or something
toyota crawler
1tonYJ project
Old 03-17-2004, 09:33 AM   #6 (permalink)
Member # 6742
Send a message via Yahoo to malkintent
what sixe are the holes in the axel brake flange?
this will tell you big or small bearing.
malkintent is offline   Reply With Quote
Old 03-17-2004, 09:41 AM   #7 (permalink)
Member # 11414
i have a 9" from the same year and truck. i was told that in order to go 35 spline, you need to replace the 3rd member. and that is all. good luck. because i am a dipshit, i only went 31 spline at the time. if i could only go back...
Distruction of the soul is vanity...
Rastamon is offline   Reply With Quote
Old 03-17-2004, 09:09 PM   #8 (permalink)
Member # 14600
Re: Ford Nine Inch
You'd probably want to upgrade to the heavier gusseted '76-'77 housing anyway and yes, you'll need another 3rd that uses the larger carrier bearings to accommodate the 35 spline carrier So, why not just go with a Warn 31 spline full floater it'd probably cost less than having to round up all the additional parts to assemble a 35 spline set up and probably be just as strong (or stronger ) than a 35 spline semi-floater anyway. I love mine! When I upgraded mine from the original 28 spline setup, I just swapped out the side gears in my 28 spline D/L and saved the cost of a new locker too ........Hans
Just a redneck trapped in a brown man's body
Oatmeal is offline   Reply With Quote
