Dana 50 hub removal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2004, 02:32 PM   #1 (permalink)
Member # 15854
Send a message via AIM to Isles4evr
Dana 50 hub removal
I am working on a 98 or 99 F250 with a dana 50 front end. I need to replace the ball joints on it, but I can't seem to figure out how to remove the rotor/hub assembly. I know it is a unitized bearing, and I am guessing that it is pressed onto the spindle. I put a puller on it, and it wouldn't budge. Any help would be appreciated...
Chris
Isles4evr is offline   Reply With Quote Quick reply to this message
Old 03-20-2004, 04:56 PM   #2 (permalink)
BUZZISCRAZY2's Avatar
Member # 17399
Send a message via AIM to BUZZISCRAZY2 Send a message via Yahoo to BUZZISCRAZY2
There are 4 bolts on the back side, and it does take a little fuckin with it..........just did balljoints too...........
[FONT="Comic Sans MS"]Catch your Dreams, before they slip away........[/FONT]
[FONT="Arial Black"]Current vehicles[/FONT]
67 Bronco
69 Bronco
81 Bronco
81 Bronco
75 F-250 (highboy)
77 F150
78 F150
70 F100 (2wd)
93 F350
95 F350 (Blown Crazy")
95 F350 ("Crazy Too")
87 Ranger (2wd)
00 Excursion
04 Navigator
BUZZISCRAZY2 is offline   Reply With Quote Quick reply to this message
Old 03-20-2004, 06:39 PM   #3 (permalink)
Member # 13219
Send a message via AIM to Dirtdragon
I just did brake rotors on a 99 dana 50.w/auto hubs.remove three screws holding hub cover,remove snap-ring retaining auto hub assy.remove center snap-ring on stub axle(holds three thrust washers)the next piece i got out with needle nose pliers(just pulls out)then remove 2/3 nut stop spring(pulls straight out)unscrew wheel bearing nut(funny looking 2 9/16 socket with corners flated)
Hope this helps
Dirtdragon is offline   Reply With Quote Quick reply to this message
Old 03-20-2004, 10:56 PM   #4 (permalink)
Member # 15854
Alright cool, I appreciate it. I'll see what I can do monday.
Thanks
Chris
