NO SPARK!!! 89 bronco II... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-27-2004, 05:23 PM   #1 (permalink)
Member # 7936
Send a message via MSN to mud-magnet
2.9L and no spark, any ideas??? worked before it was parked in nov. now nothing......
94 Sidekick buggy, 16L 8v, auto, dual cases, toyota axles, locked, coils, and 36" Swamper TSL's.
mud-magnet is offline   Reply With Quote
Old 04-27-2004, 05:25 PM   #2 (permalink)
Member # 19666
Send a message via Yahoo to ImNotRight
if it's been sitting that long look for chewed wires first..
then look at the TFI module.
QUOTE=TheHawes;15027873
If it wasn't for pussy, I'd hunt them fucking things.
ImNotRight is offline   Reply With Quote
Old 04-27-2004, 06:30 PM   #3 (permalink)
Member # 7936
Ok, where would the TFI module be located and how would I check it?
thanks
Old 04-27-2004, 06:42 PM   #4 (permalink)
1uglyranger's Avatar
Member # 6576
Does it have fuel pressure at the fuel rail??
Check for power to the TFI (located on the distributor), if it has power, disconect the PIP (inline fuse looking thing on one of the wires from the TFI), and check for spark again. If you have spark now, then check for power and grounds from the PCM/ repair or replace from there...
If still no spark, replace the TFI, and the pick-up (inside dist) in one shot. For the price, the year of the truck, and the time spent testing, just replace both, and be done with it
Brian Whitford
711
Dysfunctional Rockcrawlers
Rage 4th............ "safety is our #2 concern"
1uglyranger is offline   Reply With Quote
Old 04-27-2004, 08:09 PM   #5 (permalink)
Member # 11111
Send a message via AIM to John Deere Ranger
go to Autozone if idiots don't work there they can test it for ya
1987 John Deere Edition Ranger
Dana 60
Sterling 10.25 Rear
5.0 HO/ZF/NP203/NP205
Secretary of Navy Gideon Wells wrote n his diary that Lincoln
"thought it essential to provide an asylum for a race which he had emancipated, but which could never be recognized or admitted to be our equals."
John Deere Ranger is offline   Reply With Quote
Old 04-27-2004, 08:24 PM   #6 (permalink)
Member # 7936
Yes... HOWEVER..., I by-passed all the wiring for the 2 pumps and ran my own wires and stuck the power wire in the fuse box..
Could that have something to do with it?
Should i put the wires that came off the IRESA switch together? for a current?
maybe for spark?
thanks.., let me know.....
Old 04-27-2004, 11:31 PM   #7 (permalink)
Member # 6576
[QUOTE=mud-magnet]
QUOTE]
You did what??? Why???
If you are getting a crank signal to the PCM then the fuel pump will not pump, you will get no injector pulse, and you will get no spark. Why on earth did you hot wire the pump?
Brian Whitford
711
Old 04-28-2004, 08:12 AM   #8 (permalink)
Member # 7936
ok, i don't know what a PCM is Iam not a big FORD fan!!.... The truck turns over and when i push down on the "Bleeder VALVE" thing on the fuel rail i get lots of fuel!!
The pump did not work it was cutting in and out so I ran my own wires and set them to the Iresa switch then into the fuse box. On the accorises of the key...
When i got the truck the pump never plused when i turned the key the pump would come on and stay on....??? I don't know why but then it gave me problems in november and I layed it up and the other day I ran the new wires and bypassed all the orignal ones... and now I got no spark..?
Old 04-28-2004, 10:23 AM   #9 (permalink)
Member # 7936
OK, i think its the TFI module is there a special tool to take that off or somehing??
how does it come off..?
thanks
Old 04-28-2004, 05:21 PM   #10 (permalink)
Member # 16545
7/32 thinwall deep socket
have fun
Broncoo is offline   Reply With Quote
Old 04-28-2004, 07:26 PM   #11 (permalink)
Member # 7936
lol........ I'll try it.. We'll see what happens!!
Thanks
vj
Old 04-28-2004, 11:42 PM   #12 (permalink)
Member # 6576
PCM: powertrain control module
If I were you, I would stop working on your own truck, cause it sounds like you are making it worse. And if you keep going, pretty soon a shop won't even touch it I know I wouldn't.
And the little thing that you call an Iresa is an inertia switch. And they don't go bad
Brian Whitford
711
Old 04-29-2004, 10:05 AM   #13 (permalink)
Member # 7936
First of all i don;t really care if it gets worse .. its for the woods only and i would really want a shop to touch it thats why iam doin it my self and i never said the Inertia switch was bad or goes bad.
