Halogrinders cheap truck challenge part deux - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2017, 02:02 PM   #26 (permalink)
Dr.Danger's Avatar
Member # 168243
Originally Posted by Halogrinder View Post
It's gonna get bored and stroked.... most stroker kits im seeing is .030 over only. I'll see. looking around for a 543 or something stroker.
What's the power goal, and is forced induction or nitrous still on the table? There's a lot of .080" kits out there but if you're starting from scratch with machine work it's kind of a waste starting with a big bore imo. But, guys do it all the time, especially if you do all the machine work or can get it done super cheap.
-Dave
Dr.Danger is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 02:16 PM   #27 (permalink)
Member # 38200
The '79 up truck blocks have longer cylinder bottoms, so they can support the piston with the long stroke cranks. May need to be notched for rod clearance.
The early blocks are good for 4.3" stroke (521), no clearance notch needed. Some may have issues with the 4.5" stroke and 6.7" rods pulling the piston too far out the bottom.
Quick & Dirty is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 02:40 PM   #28 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
The D9TE blocks are a dime a dozen. Lots of fuellie trucks around that noone really wants. Slap on carbed heads and away you go. The last three I acquired were free. The longer wall is better for support, and alot of the stroker kits are external balance.
The later style crank sticks out about a half inch further on the flywheel flange though, requiring a later bell or going ZF if you stay stick. Auto it makes no difference.
An early block you can use a 390 flywheel and a 351m/400 bell, which is convenient, but later availability is much better.
Sent from my SM-G900W8 using Tapatalk
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 02:54 PM   #29 (permalink)
45acp's Avatar
Member # 13671
What are you doing with steering? That will help dictate if coils are worth it.
Coils make steering options limitless. Hydro, or just drill the knuckles and some bullshit 3/4" heims... whatever. Sure you could mill the flat tops and do high steer... too much $$$. Plain old .250 dom and when the tie rod gets up against the diff cover i chain off to a tree and straighten it.
45acp is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 03:05 PM   #30 (permalink)
Member # 232666
is it *really* worth getting the coil spring front end and converting to leaf spring, or being able to make life easy(er) with getting a leaf sprung SD axle?
Fawk, why not just convert the bastard to coil spring on the front end if I have the whole cut out
Honestly, the 05 and up axles have had less issues with ball joints and unit bearings. Plus with the ability to upgrade to 1550 joints and 40 spline so easy, the choice is easy imo. Fuck the leaf spring sd axles....I'd cut all the crap off and go leafs, if that's an absolute must. Going links isn't that hard though, coilovers are much more tunable than leafs.
Originally Posted by 03f350
... Well first off FUCK JEEPS..
sterlingfire is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 06:49 PM   #31 (permalink)
3d Artist for Hire!
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
The bullshit 3/4" heims is the way I went. I run the drag link above the arms to let it clear the diff cover. I'm also using Deaver coils and Bilstein 7100s.
Sometimes I parkerize stuff. PM for info..
animator is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 08:23 PM   #32 (permalink)
Moderhater
Halogrinder's Avatar
Member # 16980
ok so I need to come up with a solid game plan.
For now, a $ figure too.
460 is gonna come together down the road. 390 is here to stay. 40 dollar water pump and some dicking with the carb to get the damn sludge out of it, and it'll probably run this week.
I found a complete rolling frame from an 07 F250.
Do I:
Steal axles from it, convert to leaf springs and put on the 76's frame.
pros: keep it easy.
cons: labor intensive to cut the axle up to make it leaf spring.
Steal axles and front coil sprung suspension and put on the 76's frame.
pros: coil sprung front end and radius arms would probably flex better, plus I could easily move the axle forward to get it out of the cab mounts.
cons: lots of work, i think. Unsure of the 76's frame to be able to support it correctly. thoughts on strength?
Take cab and put on the SD's frame, then transfer engine/trans/tcase to SD.
Pros: superior frame, and minimal suspension work
cons: LOTS of body mount fab, positioning and making it work on that frame and cab. Divorce mount tcase will have to be sorted out, trans and motor mounts too.
Now, if I was going to go that route- this wouldn't have been the truck to by, IMO. Its got some rot on the body, and if I was to go full ham I'd want a premo cab first and just transplant it on the new frame.
I'd just bought this SD rolling chassis, found a double cab dentside and built it on there if I knew about this and was building it specifically.
But im not
gun facts that will blow your mind:
Halogrinder is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 08:24 PM   #33 (permalink)
I'm Zach
Beat95YJ's Avatar
Member # 22176
Just slap the bitch together and peel out already!
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 03-20-2017, 08:35 PM   #34 (permalink)
YotaAtieToo's Avatar
Member # 25632
I don't want to say it'd be impossible to mount leafs on an 05+ front, but it looks like a huge pita. If you do manage to pull it off they'll probably be 40 center to center.
Old 03-20-2017, 08:39 PM   #35 (permalink)
Moderhater
Member # 16980
the super60 thread or whatever the fawk its called shows some doods doing it.
hack the link things off for the radius arms and weld in a bracket
Old 03-20-2017, 08:53 PM   #36 (permalink)
Member # 25632
I'll admit, I haven't read every page of that thread.
How far is there spring spacing? Seems like with 44s it would be tough to get the springs in far enough to clear the tires.
Old 03-20-2017, 10:58 PM   #37 (permalink)
Member # 104539
as far as the frame strength.. Im not sure on the word used off hand, but basically if you weld in pieces of metal to reinforce the frame, wouldnt that be cheap and easy to do? edit: boxing in the frame?
ArTi54N is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 06:39 AM   #38 (permalink)
Moderhater
Member # 16980
The frame in the front is already boxed to about the firewall- past that its C channel and typical 70's floppy fish frame.
Old 03-21-2017, 10:31 AM   #39 (permalink)
Member # 104943
The 05+ axle coil and arm spacing needs narrowed 2-2.5" per side to bolt up to a 73-79 frame.
crazyredneckanyhow is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 11:46 AM   #40 (permalink)
Moderhater
Member # 16980
Thanks for that info. If I got it this way, Ill probably build some arms to reflect the difference on the frame out of maybe some 1 3/4 .120 DOM and use a big johnny joint for the ball.
Something like this, either split them and make the lower arm adjustable, or cut the front half off, and build off of them at an angle.
regardless, with 2-2 1/2" coming inwards they'll have to get pushed in then again to go parallel with the frame.
We'll see. This rolling frame I noticed is missing the rear leaf springs with the dark potato phone pic....
Wheres the leaf springs? "oh, I have more"....
Hmm....k....
Old 03-21-2017, 05:21 PM   #41 (permalink)
Member # 104943
Couple links involving the swap.
http://www.pirate4x4.com/forum/ford/...ns-p-pump.html
http://www.pirate4x4.com/forum/ford/...duty-tons.html
Old 03-22-2017, 06:25 AM   #42 (permalink)
Moderhater
Member # 16980
Threw a water pump, thermostat, fixed the pipe in the intake to water pump, pulled the air compressor and cleaned up some issues in the engine bay. Drove it last night to the gas station, quarter car wash and she done gud.
Gonna change the oils in everything, brake flush, adjust the clutch and rear brakes, do a Texas State Inspection and cruise it around a little.
I know, sounds stupid- but I'm curbing the project, and will be selling it off.
Why? You'll see shortly. I have something that will still be here in the Ford section, and it is much more important, personally. This is something I've been wanting to do practically my entire life. Super stoked.
It's odd. I had to buy this truck in order for this other project to start. Sometimes things like this happen in life for a reason
Old 03-22-2017, 06:35 AM   #43 (permalink)
Dr.Danger's Avatar
Member # 168243
Fawkin' Tease.
-Dave
Old 03-22-2017, 07:22 AM   #44 (permalink)
Blown7's Avatar
Member # 63754
That means I gotta find a 4sitty. I'mma talk to my machinist first- see what he's got floating around.
Jon Kasse Boss 9 off a 460 block...
1977 CJ7, 401 AMC 6-71 GMC Blower, 16 Injector EFI,
[COLOR="Yellow"][SIZE="3"]My Build [/SIZE]
[/COLOR]
2007 Jeep Grand Cherokee SRT8 for the road.
Blown7 is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 07:36 AM   #45 (permalink)
Member # 103621
Booo.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 08:35 AM   #46 (permalink)
Member # 143737
Early Bronco?
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 08:44 AM   #47 (permalink)
Moderhater
Member # 16980
Originally Posted by posford View Post
Early Bronco?
Old 03-22-2017, 09:02 AM   #48 (permalink)
Member # 143737
SO FUCKING JEALOUS
They are unicorns up here. I need one bad
Old 03-25-2017, 06:55 PM   #49 (permalink)
Moderhater
Member # 16980
Changed the Tcase, trans, front diff and engine oil. Nothing looks out of the ordinary.
popped the back axle and drum off to inspect the brakes. Whats this mean? I thought y'all said it was gonna have an 18 spline Dana 60? This is a 30 spline.
Really gave it hard look over. Needs some solid maintenance, parking brake cables, etc.etc. but its not *that* bad.
It's got a 360 according to VIN lol
in any case, I'm really at a cross roads on what to do. Right now, having this dent side and the toyota, I have two of the trucks from when I was in highskool and while I was farting around with both of them I was ... well... happy dicking around with them.
I cruised it around today. Ordered some parts. Ordered an add-a-leaf for the front springs to level it. Fixin' to order some Goodyear military 37's for it (I think) cause the 33's on there now are dry rotted. It's open front/rear so its not like it's going very far in the mud anyways.
The engine runs great! I'm gonna have to buy an oxy/acetylene torch setup to get the exhaust manifold bolts hot enough to let go so I can fix the exhaust leak. Other than that, I see no reason to mess with the engine in it's current state.
Patch panels and repair parts for the rust are stupid cheap shit, the corners of the cab are like 11 bucks lololol
I may give it to the local high school body shop and let them work on it or something.
I don't know. The more I work on it, the more I may keep it and park my piece of shit dodge lol
One thing I'm a little sketch on is the highboy push/pull power steering thingie and hydro assist ram. Is it worth a shit? I can see some bumpsteer in my future with a little lift on it. Another thing is mud/water/pushing on the hydraulic hoses coming from the frame down to the axle seems like they could get effed up pretty easy, no?
whiskey, laptop and a credit card are getting dangerous.
Old 03-25-2017, 08:20 PM   #50 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
Location: My little kingdom of awesome. Near Olympia, Thurston county, Wa
Nah. Just soak the upper manifold bolts with PB blaster for like a week. Then, run the truck and remove them hot.
Tarped lawn art: 1985 BroncoII Eddie Bauer. V8/Automagic/Locked/MTRs.
I want everyone to have everything. I want gays to be able to fuck each other in the ass, in the middle of a field of weed while shooting pistols in the air like yosemite sam shouting that there is no god.
Totalled is offline   Reply With Quote Quick reply to this message
