SuperDuty 7.3 Intercooler Mounting Grommets - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-18-2017, 10:09 AM   #1 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
I'm swapping a 1st get Cummins into a Ford Centurion and I've got a 99 7.3 Intercooler.
The intercooler's brand new and doesn't have the mounting bushings.
-the one's in the picture were scavenged off the 89s Condenser and they're cracked and a sloppy fit.
They're discontinued.
Ford PN: F81Z6C680AA
I just got back from the ACE Hardware down the street and then didn't have anything that would work.
Anyone familiar with an affordable grommet/bushing from another application that works well?
$50 Off CrawlTunes Packages:
TAWL_BOY is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 10:36 AM   #2 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
Update:
After some more searching I found the correct placement of hyphens in the PN:
F81Z-6C680-AA
The girl at the Ford dealership wrote them down without them.
By searching that, I found them at sunrisefordparts.com for under $5 each with free shipping.
We'll see if I get an email saying they're unavailable.
Old 05-18-2017, 11:32 AM   #3 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
....and I just got the email from them. Part not available.
Old 05-18-2017, 12:16 PM   #4 (permalink)
Member # 406114
I'm curious about this too, I'm just starting my cummins conversion on my 2002 f350 that was originally a gasser. Have you looked through energy suspension website? What about a shock bushing? I picked up a set from them to mount my airdog to the frame and help reduce vibration. They had 2 pages of different size and shape shock bushings.
1999 f150, super duty axles, strong box np205 doubler, 40" trail grapplers, 5.38s, Yukon zip lockers
Baron85 is offline   Reply With Quote Quick reply to this message
Old 05-18-2017, 12:22 PM   #5 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
The tab on the Mishimoto intercooler is 3/16" thick. 3/4" hole.
I've been searching Grainger and eBay. I think I might have found something that'll work.
Old 05-18-2017, 01:07 PM   #6 (permalink)
Member # 406114
Maybe something like these sway bar link bushings?
Universal Sway Bar End Links | By Size | Energy Suspension
Or these shock bushings?
Universal Shock Eye Bushings | Polyurethane | Energy Suspension
Old 05-18-2017, 02:33 PM   #7 (permalink)
Dr.Danger's Avatar
Member # 168243
For rubber (what I'd recommend over poly) that may work there are some generic shock mounts that you can grab at your local O'Reilly for $7.
Dorman HELP! 31001 - Shock Bolt Kit | O'Reilly Auto Parts
Do you still have that 460 fan shroud by chance? I got the factory part number but never heard back on the measurements.
-Dave
Dr.Danger is online now   Reply With Quote Quick reply to this message
Old 05-19-2017, 07:51 AM   #8 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Those kind look like the stock ford Radiator mounting bushing, have you tried to see if those fit?
Mark
Old 05-19-2017, 07:57 AM   #9 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
I've found some firewall grommets on McMaster that are the right size. I'm looking for the ideal ferrule to fit in the grommet.
With minimum quantities, I'll probably end up with a handful of extra.
So if it works out. I can sell extras at cost and they'll fit in an envelope.
Old 05-19-2017, 08:02 AM   #10 (permalink)
Member # 445658
Have you called Mishimoto, see if they know of an application? Could always go walk around a pick a part and start measuring other rad/condeser/etc bushings.
speedfreak78 is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 08:27 AM   #11 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
I did call Mishimoto and they didn't have any input.
Trying to avoid going to a Pick-a-part.
It's a pain around here.
Old 05-19-2017, 11:59 AM   #12 (permalink)
dieselboy740's Avatar
Member # 168108
I use a piece of rubber hose and 2 washers. When you tighten it the hose squishes out and holds it.
'97 f-250 project, boat sides, 3/4 link, caged, psd, back halved, dove tailed, fox co/ bumps, etc....
'94 f350 cclb drw 7.3idi-t
'93 Volvo 940 fake rally car #trophyvo
'94 international 4700 toter build
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 09:22 PM   #13 (permalink)
unit dude
FORDTECHGURU's Avatar
Member # 104639
Dodge intercooler mounts are similar also, go to a radiator shop, they will have a bucket full of bushings like that..
FORDTECHGURU is offline   Reply With Quote Quick reply to this message
Old 05-24-2017, 07:39 AM   #14 (permalink)
Member # 445658
I have a stock 7.3 IC and a stock dodge IC. I just checked them, the upper round mounts on a 94-02 dodge ram intercooler are the same.
https://puredieselpower.com/dodge-pr.../product/17578
Old 05-25-2017, 05:12 AM   #15 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
Sweet. That'll do.
Old 05-25-2017, 06:01 AM   #16 (permalink)
fredycruger's Avatar
Member # 225557
1" hole saw and tire sidewall makes nice rubber grommets
fredycruger is offline   Reply With Quote Quick reply to this message
Old 05-25-2017, 06:56 AM   #17 (permalink)
CrawlTunes
TAWL_BOY's Avatar
Member # 72810
I'm pretty sure that'll work on my A/C condensers upper mounts too.
