9" U-joint - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-05-2001, 11:10 AM   #1 (permalink)
Member # 6111
Send a message via AIM to Trigger
Post 9" U-joint
What size U-joint will be on the pinion side of a 79 Bronco? Is it a 1310?
Perpetual Newbie
Trigger is offline   Reply With Quote
Old 10-05-2001, 11:30 AM   #2 (permalink)
Aggro's Avatar
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
Post
I do believe so.
Aggro is offline   Reply With Quote
Old 10-05-2001, 12:21 PM   #3 (permalink)
Member # 792
Post
I think so too.
01 TJ
Dan-H is offline   Reply With Quote
Old 10-05-2001, 01:26 PM   #4 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Post
hmm not to sure, but i thought the big bronco used a little bigger one like a 1320 or something
Mark
welndmn is offline   Reply With Quote
Old 10-07-2001, 09:02 PM   #5 (permalink)
Member # 1546
Post
its bigger then 1310 i thought. its wider. the cross is bigger
pat
happiness in life is having a tight posi
broncoboy is offline   Reply With Quote
Old 10-07-2001, 09:47 PM   #6 (permalink)
Member # 7423
Post
Are the crosses equal in length?
The 1330 is basicly 1 ton width (1350) with 1/2 ton size caps (1310)
Bill Mish
President
Arizona Rock Crawlers
yldkat is offline   Reply With Quote
Old 10-08-2001, 11:06 AM   #7 (permalink)
Member # 6350
Post
78's used a 1310 at the pinion, 79's went to 1330 series. Many times these vehicles have had swaps done over the years. With so many options for the 9" it's very iffy to guess at which U-joint IS in there, I can tell you which one should be there, and if you give me the needed specs I can tell you what spicer joint would replace it.
My 78 Bronco
[ 10-08-2001: Message edited by: Bronco78 ]
[url="http://www.bronco78.com"]bronco78.com[/url]
[url="http://www.superford.org/registry/?vID=144"]Bronco Specs[/url]
[url="http://www.teamalaska4x4.com"] Team Alaska[/url]
[url="http://www.outbackchallenge.com"]Australian Outback Challenge
[/url]
bronco78 is offline   Reply With Quote
Old 10-09-2001, 05:15 AM   #8 (permalink)
Aggro's Avatar
Member # 2587
Post
my '79 had 1310 at the pinion and 1330 at the tcase, and 1330 both sides on the front.
Old 10-10-2001, 07:44 AM   #9 (permalink)
Member # 6350
Post
Keeping in mind I am only stating what was on the books as specified for a particular year, and drive line combo and that mother Ford has a reputation of instaling what ever is at hand and who knows what has been swaped on a vehicle you bought used.
1978 Broncos came with one of three different rear drive shafts depending on drive train 1310 series on both ends unless equiped with the 400 eng, then it was 1310/1330
1979 Broncos came with one of three different rear drive shafts depending on drive train but all used 1330 series joints at both ends EXCEPT when equiped with a 351M/auto trans/NP205, then it was 1310/1330 5-153x (1310) at the pinion and 2ea 5-278x (1330)at the TC.
I fully admit this is all book data, and what is under your bronco may differ, but for what it is worth there it is.
[/url]
