Member # 191
I think I may have roasted a bearing or something, and need your input desperately!
Forgot to unlock the front hubs for approx 40 miles at freeway speeds recently.. oops. Now when the tranny (E4OD) shifts from 2-3 and sometimes 3-OD, something is making a "chatter" like sound. I'm pretty sure its coming from the transfercase, not the tranny. I tried this morning putting it in 4x4 hi range to see what happens. It made the same noise, but at all almost all speeds/shifts. So, help me guys, this is my daily driver. Either I have to buy a rebuilt case, or try to dismantle it myself, but I don't have much time.... Thanks a ton. And if anybody can recommend a shop in San Jose, (one that YOU personally know their reputation) I'd appreciate that as well)..... hep me, hep me, hep me.............. Sherpa
[QUOTE][i]Originally posted by LAME [/i] [B] The guys designing cages for the D9 dozer on your Christmas list are going about this a bit differently way then a few rednecks, too much beer, and a JD2:D [/B][/QUOTE] |
Member # 324
just running with the hubs locked isnt gonna hurt something. make sure of the problem. when i lived in elko i locked the hubs in Nov and unlocked them in march and never hurt a thing.
Family, Friends, riders and racers, its who we are. |
Well Done Man!
sounds like a drive shaft, either your pinion nut on the diff has come loose or your CV has gone bad, climb under the truck, set the P-brake, and leaave it in N, grab the sfat and try and move it up and down, if it has play up and down find out where the play is and that where its bad
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
Member # 191
thanks for the replies.. Mark, er,
Bent-welderman, It's not the d-line. Recently replaced all 3 ujoints only 500mi ago, and the center cariier bearing. (NO cv) on this one. It only does the "bearing- chatter" sound inbetween the shifts. mainly 2-3, sometime 3-OD... The sound is kinda like this: (example) If you have ever played around with a bearing using air to spin it, and it gets going really fast, then gets to a point in which it does the "bearing-chatter" thing, and slows itself down, that is what I think is occurring somewhere under the truck. (and yes I already know to not spin-dry bearings) but it's kinda fun to do with the old ones you're not gonna use again.. back to the truck problem... My main hope is that it's not in the tranny. I'd die if it's that again. the transfercase is cheaper, and I can probably do that myself. I might even be buying a cheapo-4x4 runner for using while the Fomoco is down for the repair.... THanks all, keep the relies coming, please! Sherpa
