1978 tracbar question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-20-2001, 07:26 PM   #1 (permalink)
Member # 3103
Question 1978 tracbar question
Gents,
I have a problem. I replaced my lower tracbar mounting bolt with the ingalls kit and that has been super. When I did that I replace the bushings with a set of Moog problem solver urethane bushings. Everything was fine for a couple of hundred miles and the popping started again and it was at the frame mount. I have a drop bracket that came with the lift system. I can see the bar moving around the bushing when the wheel is turned. What are your suggestions? Do I need an adjustable tracbar, heim joints, what? Thanks.
tuffguy is offline   Reply With Quote
Old 08-20-2001, 07:55 PM   #2 (permalink)
Member # 4068
Send a message via ICQ to TX4WHEELER
Post
I have had similar problems on my 78. I replaced the bushings, tapered stud in the D44 housing and even strengthened up the frame mount for the track bar. I have also tried heim joints. My problem has been the death shake. I do know the drop bracket for the trac bar adds more leverage where an adjustable trac bar doesnt. Good luck
Robert Hutson (TX4Wheeler)
1978 Ford Bronco
460, C-6, D60 Front with ARB and 35 spline outers, D70 rear, disk brakes, welded diff,7" lift, 38.5X14.50 TSL/SX's, Warn 8274 winch, Hydro Assist steering
TX4WHEELER is offline   Reply With Quote
