86 Bronco front axle question... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-16-2004, 10:03 AM   #1 (permalink)
HighToy's Avatar
Member # 1983
Send a message via Yahoo to HighToy
A buddy of mine just picked up an 86 Bronco and the front pivot axle is pretty much shot. He would like to know which straight axle would be best to put in the front to replace the pivot style axle.
I would recommend a 44 but just want to check with you guys that actually know ford.
Ryan
The Original Techno Hick.
HighToy is offline   Reply With Quote
Old 07-16-2004, 10:28 AM   #2 (permalink)
Member # 33205
The pivot axle is call a TTB Twin Traction Beam. A buddy of mine has a 94 and we did a soild axle swap to a dana 44 and then to a dans 60. You are on the right track.
Chack out his site an goto the dana 60 swap.
http://www.superford.org/registry/ve...ail.php?id=211
ALLAXCS is offline   Reply With Quote
Old 07-16-2004, 10:44 AM   #3 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
D44 from a 78/79 bronco, almost bolts in
Mark
welndmn is offline   Reply With Quote
Old 07-16-2004, 05:05 PM   #4 (permalink)
Member # 11894
i have a 86 bronco and idid a sas and it was pretty straight forward but i would take your time and measure everything to make sure it is in their correctly i also recommend using 78 or 79 coil buckets cause the springs flex better
i have skyjacker springs for right now and i think they flex pretty well but if you want real good flex go with the jeffs bronco graveyard super flex series springs and use either after market radius arms like the james duffs or wristed arms
rokdog03 is offline   Reply With Quote
Old 07-16-2004, 06:21 PM   #5 (permalink)
Member # 10063
Get the D60. What's in there is already a D44 (although a straight D44 will be easier to put alloy shafts & stuff in, it still will end up costing about what just putting a D60 in would cost, and still won't be as strong)
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 07-16-2004, 09:34 PM   #6 (permalink)
Member # 26592
D60's are expensive, easily looking at $800 - $1500 for just the axle and easily that much more to be rebuilt. This is where you have to decide what you want, a D60 will take more fab to get it under yer truck but will survive more punishment. D44 solid is easy to swap and are cheap to buy, but aren't as strong, but can be built up to take mild punishment.
1993 F150 XL 4X4
393ci Stroker
4.56 gears, D44 Solid front, detroit locked 9" rear, ZF S5-42, Twin-Stick 205, 38.5" Hawgs
fordperf351w is offline   Reply With Quote
Old 07-19-2004, 05:43 PM   #7 (permalink)
Rapey
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
I got a 78 F-150 44 to swap under my 93 F-150.... I'll be spending the next few weekends swapping it in and posting progress....
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum:
http://www.pirate4x4.com/forum/outdo...-may-31-a.html
animator is offline   Reply With Quote
