please fix my runner
broken radius arm
My brother broke the drivers side radius arm on his 96 F150 drivers side, where can he get aftermarket arms that are either tubular or extended? Or both. HE already has the SUperlift 4' kit on the truck...
4.3runner ---A golf course is a pointless exploitation of a perfectly good rifle range--- buy my ultra rare Omega III presentation rifle special price $42500.00 |
Well Done Man!
4wPW, just about anywhere will sell you a set.
Online all I can think of is http://www.broncograveyard.com/ But it would be cheaper to get them local
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
Rapey
Depending on how soon he wants it, I've got the stock ones on my 93 that I'd let him have, but it'll be another week or so before I'll be able to take them off. Of course, it's not aftermarket, but if he does end up needing them, let me know in a week or two and I'll see what I can do.
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum: http://www.pirate4x4.com/forum/outdo...-may-31-a.html |
Member # 11420
Check out this link www.camburg.com/fordsibeamf150p.html
There is nothing better than being on the trail |
You can try www.Wildhorses4x4.com. They are located in Stockton, CA and have a good catalog online to browse.
1970 Bronco, 5.0, NP435, Dana 20 W/Rock Eater 4.86 gears, 35 BFG Muds, Currie 9in w/Detroit, Dana 44 w/ARB Does anybody have a cure for Bronc-ITIS? |
Member # 10063
Both Skyjacker & Superlift have extended arms.
The Skyjacker is tubular, the Superlift, welded/boxed. Tuff Country makes some also, but they appear a bit flimsy. The Superlift F-150 arm APPEARS to be pretty stout, but the same can't be said about almost anything else they make TTB related (including their Ranger radius arms) ![]() I've yet to see a tweaked Skyjacker Ranger radius arm, but I have seen one tweaked fullsize one. How 'bout making your own arms out of stockers using DOM tube? Then you can make it as strong as you want.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] Last edited by 4x4junkie; 08-09-2004 at 07:19 PM. |
Member # 16680
cageoffroad.com makes nice arms for ttb'ers
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club |
OKAY, first thanks for all the replies...he cannot make them as he has no fab skills and I will probably end up installing them for him anyway...
next, he called and said he ordered a set of extended tubular arms from a company called BDS for about $400 includes shipping and the drop brackets that mount farther back on the frame than the factory OR the replacement drop brackets that gave it the lift before. They assured him he would have them by Friday and that they would be direct replacements for what he has and his 4" lift would be maintained. So, has anyone else BROKEN these? they are factory units and the drivers side one broke where it goes from stamped metal to the threaded section...it was not the threaded area that broke. and I can guarantee you that this truck hasn't seen any REAL offroad since the lift was install a few months ago. It is a DD and sees some MILD off pavement use in OKLA and some trail runs in COLO... I will get some pix this Sat and post them so you can see what happened and the solution. thanks again.
Member # 10063
The stock arms are pretty stout.
Yea, post some pics. I can't say anything about the BDS arms for strength (not familiar with them), but I know their warranty is a big thing with them. Supposedly they'll replace anything no questions asked.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] |
Member # 11420
I had a ProComp 6" lift with the extended rad arms I broke the driver side while in town (well that is when I found out) that sucked but I sent it to them they sent me a new set. That was after about 2yrs of wheeling it. It broke at the "C" both ears broke off
Oh I would not run drop brackets
#12 (permalink) |
Okay, the parts arrived yestrday afternoon, so I drove up to Lawton and we did the install...
Here is the broken part...
#13 (permalink) | |
Member # 6733
Team Fat Shit and the Traveling Circus |
#16 (permalink) |
Member # 10063
Those bushings on the old arm wouldn't happen to be those super-hard almost like plastic ones would they? I wonder if that could've caused it to snap. I've seen such bushings at an autoparts store and was like "WTF!??"
#17 (permalink) |
The old bushings are poly and pretty stiff, but they have wear marks in them, so they must not be that hard...not like the rubbers that were there...anything is possible...
the ride with the new longer arms is like night and day compared the the originals...talk about a smooth ride...and the flex is TWICE as good, the shock is now the limiting factor for downtravel and the factory placed top bumpstop can be contacted in uptravel....
